Strain Gauge and HX711 break out board.
I am a mechanical engineer currently investigating the possibility of accurately measuring the strain within a mechanical member under load with an arduino. I am familiar with strain gauges, their theory, how to use them, and of the Wheatstone bridge setup.
To amplify the voltage readings I intend to use the HX711 breakout board (mainly because it is the only component locally available and I live in a country where it is very difficult, and expensive, to order components online).
Referring tho the Wheatstone diagram attachment:
E = Excitation voltage (input voltage)
e0 = output voltage
Is it possible to retrieve the mV reading from the HX711 board of the e0 parameter?
Is the HX711 sufficient for this purpose, or do I need to look at alternatives?
Any help will really be appreciated.
Thank you.
FrancoisStevens:
e0 = output voltage
Thank you.
  1. Yes, many libraries for HX711 provides an output data in mV or raw binary, knowing reference voltage it's easy to re-calculate ether way binary to mV and vice versa.
  2. If you can, alternatives ads1232 is much better, on average 100x times more accurate and less noisy
