Strain gauge (Volts to force conversion)
Hello,
I have been working with strain gauges for a while now and I am able to collect data through an Arduino Nano. I am not completely sure how to convert this data which is in volts to force (N). I believe the strain gauge data sheet should have it but all I can find is the sensitivity coefficient measure of 2 mV/V. I know that this parameter tells me that there is a 2mV change for every 1V increase in the input voltage. Could this help me find out the amount of force?
I have attached all the information I have regarding the strain gauge
Thank you all in advance
Run som tests and calibrate using known weights.
