Strange Arduino error messsage
The Attached sketch was cut and pasted from a site.
I saved to my computer as a Sketch and all works fine,sometimes.
The receiver sketch is ok but the transmitter sketch sometimes compiles but more than not,
it wont compile and throws up the error;
“a function-definition is not allowed here before ‘{’ token”.
I can try to compile the sketch repeatedly but 8 out of 10 times it wont compile.
Can anyone help me diagnose the problem.
Have tried it on several different UNO’s
// TRANSMITTER
  #include <RH_ASK.h>
#include <SPI.h> // Not actually used but needed to compile
#include <String.h>
RH_ASK driver;
float volt_sensor, current_sensor;
int trip_sensor;
    if (!driver.init())
    Serial.println("init failed");
 volt_sensor = random(200, 245); // generate some random Data
 current_sensor = random(0, 500);
 trip_sensor =random(1, 4);
    String final_data = String(volt_sensor) + "|" + String(current_sensor) + "|" + String(trip_sensor); //final_data hold all varibles.
    const char *msg = final_data.c_str();;
    driver.send((uint8_t *)msg, strlen(msg));
    driver.waitPacketSent();
Error Message.txt (1.86 KB)
The code you posted there goes like this:
You are starting a new setup() inside the original. Apart from the fact you can’t have 2x setup()s anyway, even if you could, you can’t define any function inside another one.
So that code is surely not compiling even 2x out of 10…
Thank you.
Its so obvious when its pointed out to you.
I think it may have compiled the few odd times I used the original sketch
It seems that I didn't clear out the new sketch before pasting in the new text.
Appreciate your help
Farticus:
I am not without sin, I cast no stones :wink:
