I have a strange little thing happening with a voltage regulator. It is a extra deluxe Chinese buck converter which I have used multiple times and it works ok for powering an Arduino.
The thing is I get some strange distortion when I measure it with the scope. Even stranger (for me at least) is that the distortion happens after I have added cables to the out ports.
When I measure at the screw terminal it looks fine:
I have tried different cables but get the same result.
Very peculiar in my eyes. Some kind of resonant frequency issue perhaps? I am guessing wildly here
Yep, the output cap is ok If I measure at the start of the cable everything is fine but when I measure at the end of it the distortion appears. This leads me to think that the antenna idea is pretty possible.
Is the gnd clip of your scope connected to the other gnd terminal where you are measuring?
Do you have a load on the regulator?
Don't forget that regulator is a SMPS so will have noise on it already.
Depending on the quality Chinesium it was made from, the performance may suffer.
Yes I can see no ground clip in the picture here, but the previous measurement with no output wires you can see the scope-probe ground clip is connected to the input ground as it needs to be.
My vote is a spurious reading due to not connecting the ground clip. This makes the entire setup into a large loop antenna.
That is what is so confusing but also makes me think that the “antenna idea” might be on to something.
The only difference I make between the readings is moving from the screw terminal where the black cable is attached to the end of the cable, approximately 15cm.
I wouldn't call that 'connected'. It's basically floating in space, in general proximity of where it should be connected. Just lying two loose pins next to each other is NOT a good way of making a contact...
No, you put a crocodile clamp onto the GND lead allowing for a better contact and hence a better measurement...
