I'm using an Uno to talk to TI Gas Gauge battery monitors. I'm using Arduino 1.6.2 to write the code.
When I run this code:
char Man_BlockA[33]
char Man_BlockB[33]
char Man_BlockC[33]
void dump_man_blocks() { // Read and dump all 3 manufacturer blocks
read_MBA();
read_MBB();
read_MBC();
Serial.println(F("Manufacturer Data Blocks:"));
Serial.println(F("0....5....1....5....2....5....3.."));
for(byte i = 0; i < 33; i++) Serial.print(Man_BlockA[i]);
Serial.println(); for(byte i = 0; i < 33; i++) Serial.print(Man_BlockB[i]);
Serial.println(); for(byte i = 0; i < 33; i++) Serial.print(Man_BlockC[i]);
Serial.println(); Serial.println();
I get this output:
˜öH9BH
F5D606219FNFW5VCR
Which is what I want, except that some non-printing characters show up and mess with the alignment. Since I don't care about non-printing characters (I'm looking for an ASCII serial number string) I changed it to this:
char Man_BlockA[33]
char Man_BlockB[33]
char Man_BlockC[33]
read_MBA();
read_MBB();
read_MBC();
for(byte i = 0; i < 33; i++) sprintable(Man_BlockA[i]);
Serial.println(); for(byte i = 0; i < 33; i++) sprintable(Man_BlockB[i]);
Serial.println(); for(byte i = 0; i < 33; i++) sprintable(Man_BlockC[i]);
void sprintable (byte ch) {
if(ch < 32) {
Serial.print(F("."));
}else{
Serial.print(ch);
But now I get this output:
152246.72576672..........................
7053685448545049577078708753866782................
It's outputting decimal ASCII codes instead of characters!
After much head-scratching and a shrug, I tried this:
char Man_BlockA[33]
char Man_BlockB[33]
char Man_BlockC[33]
read_MBA();
read_MBB();
read_MBC();
if(ch < 32) {
}else{
Serial.write(ch);
All I did was change Serial.print(ch) to Serial.write(ch). And now I get the output I'm after:
˜ö.H9BH..........................
F5D606219FNFW5VCR................
So, I guess, problem solved. But inquiring minds want to know why that second version doesn't work? What am I doing to Serial.print that makes it output the numeric value instead of the actual character? (I might want that behavior some other time
