Hi All,
This is my first post here, and I am stuck for a few days on this problem and I cant find the solution on the web/in the forums.
I am making an device to control inputs in Microsoft Flight simulator and display the simulation variables on the touchscreen. Serial is used to communicate with an C# tool on my PC (not part of this code), and Serial1 is used to communicate to the touchscreen.
Hardware:
- Arduino Mega (Geekcreit)
- nextion 7 inch intelligent touchscreen
- Rotary encoder
Encoder is connected to:
Digitalpin 2 = encoder switch
Digitalpin 3 = Data pin on encoder
Digitalpin 4 = Clock pin on encoder
And of course + to 5v and – to ground.
Screen is connected to
TX1 18 = RX of the screen
RX1 19 = TX of the screen
The following code is a selection of the code to demonstrate the problem. If I run the code and turn the encoder to the right I get random “Left” / “Right” prints in the debug monitor. The same applies for turning left.
If I commend out the method “SentDataToScreen()” the encoder works as expected. So the Serial1.print / Serial1.write looks to interfere with the digitalRead.
int encoderOutA = 4; // CLK pin of Rotary Enocoder
int encoderOutB = 3; // DT pin of Rotary Enocoder
int encoderPush = 2; // sw pin of Rotary Encoder
int buttonStatus = 0;
int presentState = LOW;
int previousState = presentState;
Serial.begin (115200);
Serial.setTimeout(50);
Serial1.begin(9600);
//Setup Rotery encoder
pinMode (encoderOutA, INPUT);
pinMode (encoderOutB, INPUT);
pinMode (encoderPush, INPUT_PULLUP);
ReadDataFromEncoder();
SentDataToScreen();
void ReadDataFromEncoder()
//Rotary
presentState = digitalRead(encoderOutA);
if (presentState != previousState)
if (digitalRead(encoderOutB) != presentState)
Serial.println("Right");
Serial.println("Left");
//PushButton
int btn = digitalRead(encoderPush);
if (btn != buttonStatus)
if (btn == 0) //Button is pushed
Serial.println("PushButton");
buttonStatus = btn;
void SentDataToScreen()
Serial1.print("t2.txt=");
Serial1.print("\"");
Serial1.print("info");
Serial1.write(0xff);
I hope someone can help with this problem
Thanks in advance!
