I am using an external DC power supply, powering the Arduino Uno with 9V and with 12 V. With lower V it does not work. When I press the switch nothing happens. But when I randomly touch the wire from output 4 th motor runs for a second and slows down, runs and slows down and so on...
So i put the wire, currently in the output pin 4 in the nearby GND pin. Same behaviour as touching the wire.
So what is wrong with the setup? Why the switch doesnt cause any response?
yes, but I am using an external power supply, not a battery. Both motors I tried work wit
4,5 Volt, 65 mA
4,5 Volt, 220 mA
Thanks
As a motor starts up it will pull stall currents, typically many times the free-running current, the
short term overload will pull the supply voltage down and force the Arduino to reset.
Stall currents are simple to work out, measure the resistance across the motor terminals with it
at rest - I = V / R
filyra:
If touching the wire connected to pin 4 makes the motor run, that indicates that your code has not set pin 4 to be an output. Post your code.
