Strange character in display
I am working on a dual stepper motor design.
So i would like to display the to go value (X/Y) and the ‘actual’ values (Dish).
But strangly there are two strange characters on the second line of my 4 line I2C display.
This i the sketch for testing:
#include "Arduino.h"
#include <Streaming.h>
#include <Wire.h>
#include <LiquidCrystal_I2C.h>             // http://www.dfrobot.com/image/data/DFR0154/LiquidCrystal_I2Cv1-1.rar
#include <AccelStepper.h>                  // http://www.airspayce.com/mikem/arduino/AccelStepper/index.html
// PINS
int      YAxisDIR          =  13;          // Stepper direction output
int      XAxisDIR          =  12;
int      YAxisPWM          =  11;          // Stepper steps output
int      XAxisPWM          =  10;
// DEGREES / STEPS CONVERSION
float    stepsPerRotation  = 200;          // 200 steps per rotation (1.8 degrees per step)
int      xGearRatio        =  42;          // stepper ratio per X degree of rotation (1:42)
int      yGearRatio        =  42;          // stepper ratio per Y degree of rotation
int      xMicroSteps       =   2;          // Value of the microsteps
int      yMicroSteps       =   2;          // Posible value's are 1, 2, 4, 8 and 16
int      xOffset           =   8;          // Numer of degrees offset from 0 or 180 degree
int      yOffset           =   8;          // Numer of degrees offset from 0 or 180 degree
typedef enum {
  X_ROTOR, Y_ROTOR }
stepperfn;
long deg2step( float degrees, stepperfn stepper );
long deg2step( float degrees, stepperfn stepper ) {
  if(stepper == X_ROTOR)	return (( degrees/1.8)*xMicroSteps*xGearRatio);
  if(stepper == Y_ROTOR)	return (( degrees/1.8)*yMicroSteps*yGearRatio);
float step2deg(long steps, stepperfn stepper);
float step2deg(long steps, stepperfn stepper) {
  if(stepper == X_ROTOR)        return (( steps*1.8)/(xMicroSteps*xGearRatio));
  if(stepper == Y_ROTOR)        return (( steps*1.8)/(yMicroSteps*yGearRatio));
// Steppers , see AccelStepper documotation for more information
AccelStepper stepperX(1,XAxisPWM,XAxisDIR);
AccelStepper stepperY(1,YAxisPWM,YAxisDIR);
byte     lcdDisplayAddress = 0x21;
int xMotorSpeed            = 500;          // Maximum steps per second
int yMotorSpeed            = 500;          // Maximum steps per second
int xMotorAccel            =  25;          // Steps per second for acceleration
int yMotorAccel            =  50;          // Steps per second for acceleration
float newXAxis = 23L;
float newYAxis = 13L;
char     xStrBuffer[8]     = {
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
char     yStrBuffer[8]     = {
// LCD display and Keyboard
LiquidCrystal_I2C lcdSerial(lcdDisplayAddress, 20, 4);
  Serial.begin(19200);                     // Start the Serial communication
  while(!Serial);
  lcdSerial.init();                         // Initialize the LCD display
  lcdSerial.backlight();                    // Turn on the back-light
    stepperX.setMaxSpeed(xMotorSpeed/1);        // Set the X rotor-motor maximum speed
  stepperX.setAcceleration(xMotorAccel);    // Set the X rotor-motor acceleration speed
  stepperY.setMaxSpeed(yMotorSpeed/1);        // Set the Y rotor-motor maximum speed
  stepperY.setAcceleration(yMotorAccel);    // Set the Y rotor-motor acceleration speed
  stepperX.setCurrentPosition(deg2step(0.0, X_ROTOR));
  stepperY.setCurrentPosition(deg2step(0.0, Y_ROTOR));
  Serial << "Test Setup Ready" << endl;
  stepperX.moveTo(deg2step(newXAxis, X_ROTOR)); // Move to new X position
  stepperY.moveTo(deg2step(newYAxis, Y_ROTOR)); // Move to new Y position
  dtostrf(newXAxis,7, 2, xStrBuffer);   // Make it alse printable
  dtostrf(newYAxis,7, 2, yStrBuffer);
  lcdSerial.setCursor(0,1);
  lcdSerial << "X/Y " << xStrBuffer << "  " << yStrBuffer;
  while(stepperX.currentPosition() != deg2step(newXAxis, X_ROTOR)) {
    stepperX.run();
    stepperY.run();
    lcdSerial.setCursor(0,2);
    dtostrf(step2deg(stepperX.currentPosition(), X_ROTOR),7, 2, xStrBuffer);   // Make it alse printable
    dtostrf(step2deg(stepperY.currentPosition(), Y_ROTOR),7, 2, yStrBuffer);
    lcdSerial << "Dish" << xStrBuffer << "  " << yStrBuffer << endl;
The characters on the first 2 position of line 2 look like 3 horizontal stripes.
Anny suggestions?
Harry
Why are you casting an int to a long, and storing the result in a float?
The characters on the first 2 position of line 2 look like 3 horizontal stripes. Anny suggestions?
I suggest you post a picture of it, since you didn't define what the rest of the display looks like.
I'd also suggest that maybe the two buffers should be a bit larger - say 10 elements.
Hi Paul,
Attached is the picture of what i see.
The buffer should only hold the 7 characters to print plus the ending 0x00 as needed by the dtostrf function.
By using a buffer that’s only eight positions long it should work, making it longer doesn’t change the result.
I’m curious what you expect the LCD do to with the carriage return and line feed. They often result in garbage on the LCD. Hmmm, I know someone who’s having that kind of problem.
Is that really easier to deal with than:
lcdSerial.print("X/Y ");
lcdSerial.print(xStrBuffer);
lcdSerial.print(" ");
lcdSerial.print(yStrBuffer);
Your code certainly uses more memory.
Sorry Paul,
Youre answer makes no senso to me.
There’s no CR+LF in that line.
I am using streaming all the time without problem.
With streaming, if i would have a CRLF i use << endl;
And it uses noextra memory.
Harry
Sorry Paul,
The endl does something. Perhaps you ought to write a program in C++ on your PC, and see what happens if you don’t use endl.
Exactly. And what is the LCD supposed to do with a carriage return or a line feed? It is NOT a printer!
That I do NOT believe.
