Program is to regulate temp, humidity and light cycle (water cycle to be added later) for..... GROWING POT. yeah, that's right, I'm Canadian, I can actually say it. lol.
Everything appears to be working fine but if the program runs ~24h+ I get very strange characters appearing on the LCD. I'm starting to think maybe there's a problem with the way I'm calling variables in the timer section?? Or is there something inherently bad about the way I've structured it?
Any advice would be appreciated. It's been running fine for roughly a week so long as I reset it once a day but the point was to be able to get away and leave the girls for a few days once in a while lol.
Light, heat and humidity control for grow room
//libraries
#include <LiquidCrystal.h>
#include "DHT.h"
//definitions
const int lightout = 6, heatout = 7, fanout = 9, timeset = 10;
int lightstate = 1, heatstate = 0, fanstate = 0, timestate = 0;
short seconds, minutes, hours;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
#define DHTPIN 8
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
//open serial
//set pins as ins or outs
pinMode(lightout, OUTPUT);
pinMode(heatout, OUTPUT);
pinMode(fanout, OUTPUT);
pinMode(timeset, INPUT);
// start temp/hum sensor
dht.begin();
// set up the LCD's number of columns and rows and print initial text
lcd.begin(16, 2);
lcd.print("Te: Hu: Ti:");
//reset time to zero. set startup states for apppliances
hours = 0;
minutes = 0;
seconds = 0;
digitalWrite(lightout, LOW);
digitalWrite(heatout, HIGH);
digitalWrite(fanout, HIGH);
//data to lcd. temp, humidity and hours of light cycle
lcd.setCursor(0, 1);
float h = dht.readHumidity();
float t = dht.readTemperature();
// 5% calibration for DHT
t = t - (t*0.20);
if (isnan(h) || isnan(t))
lcd.print("ERROR");
return;
lcd.print(t);
lcd.setCursor(6,1);
lcd.print(h);
lcd.setCursor(12,1);
lcd.print(hours);
//temperature control
//heater control
if (((t < 22.00) && (lightstate == 1)) || ((t < 17.00) && (lightstate == 0)))
digitalWrite(heatout, LOW);
heatstate = 1;
if (((t > 28.00) && (lightstate == 1)) || ((t > 23.00) && (lightstate == 0)))
heatstate = 0;
//fan control
if (h > 72.00)
digitalWrite(fanout, LOW);
fanstate = 1;
if (h <= 65.00)
fanstate = 0;
//twelve hour timer which toggles the light
if (hours == 12)
hours = 0;
minutes = 0;
seconds = 0;
digitalWrite(lightout, !digitalRead(lightout));
lightstate = !lightstate;
lcd.setCursor(12,1); //clear second digit from time display
lcd.print("0 ");
else if (minutes == 60)
minutes = 0;
seconds = 0;
hours ++;
else if (seconds == 60)
seconds = 0;
minutes ++;
seconds++;
// pressing a button advances the hours by 1
timestate = digitalRead(timeset);
if (timestate == LOW)
hours ++;
//print data to serial for debugging
Serial.print("Temp = ");
Serial.print(t);
Serial.print(" Hum = ");
Serial.print(h);
Serial.println("% ");
Serial.print("Time = ");
Serial.print(hours);
Serial.print(" : ");
Serial.print(minutes);
Serial.println(seconds);
Serial.print("Light: ");
if (lightstate == 1)
Serial.print("ON ");
if (lightstate == 0)
Serial.print("OFF ");
Serial.print("Heat: ");
if (heatstate == 1)
if (heatstate == 0)
Serial.print("Fan: ");
if (fanstate == 1)
Serial.println("ON ");
if (fanstate == 0)
Serial.println("OFF ");
