Strange chip
Hi guys ,
I recently took apart some old sound cards and modems that i had laying around and i came across a chip which is an 8 pin dip and is marked as follows
ATMEL 718
93C66
PC27
I typed ATMEL 718 into google and it came up with Atmel datasheet pdf catalog - Page 8
i scrolled down and looked at the data sheet for 718 and it says it is a 2wire eeprom.
if this is so i can use it but as the other part numbers dont match i am asking if anyone here knows what it might be or if i am correct ?
Chris
A 93C66 is a common serial eeprom chip...
4k bits (512 bytes)
It can be a bit tricky to find the part number among the other stuff that chip vendors like to print on their chips...
The 718 number on the link you provide seems related to the site and nothing to do with Atmel.
Instead, I went to atmel.com and typed in what looked like an actual part number "93C66" and found what looks like the actual datasheet for the part: http://www.atmel.com/dyn/resources/prod_documents/doc0172y.pdf
It looks like it has a command to prevent future programming. It is possible that the part is no longer writeable. The protocol to talk to the chip looks pretty straightforward, if there isn't already a library for it.
Many thanks for that but unfortunately according to the data sheet it is a 3 wire interface :frowning:
And i wonder what it was doing on an old ISA sound card ?
Saving settings for soundblaster maybe?
3-wire interface - that's just SPI. Clock, Data out (MOSI) and data in (MISO), and chip select.
Probably have to issue an Erase/Write Enable command before you can change any memory locations.
Thanks crossroads I will investigate :slight_smile:
