Strange code behaviour/output
So I have a code that converts CAN messages to text. All works good until it reaches the last array position. That is the moment that the conversion goes weird, and starts going in some sort of a loop, because it does not exit the function, as it should.
#include <mcp2515.h>
struct can_frame canMsg;
MCP2515 mcp2515(10);
String frequency_box;
String function_name;
String endString = ":end_string";
  Serial.begin(2000000);
  mcp2515.reset();
  mcp2515.setBitrate(CAN_500KBPS, MCP_8MHZ);
  mcp2515.setNormalMode();
//Channel number function
String chan_number(char recv_char){
  String ch_nr = "0";
  if (recv_char == 0x10) ch_nr = "1";
  if (recv_char == 0x11) ch_nr = "2";
  if (recv_char == 0x12) ch_nr = "3";
  if (recv_char == 0x13) ch_nr = "4";
  if (recv_char == 0x14) ch_nr = "5";
  if (recv_char == 0x15) ch_nr = "6";
  if (recv_char == 0x46) ch_nr = "7";
  if (recv_char == 0x47) ch_nr = "8";
  if (recv_char == 0x48) ch_nr = "9";
  if (recv_char == 0x49) ch_nr = "10";
  if (recv_char == 0x4A) ch_nr = "11";
  if (recv_char == 0x4B) ch_nr = "12";
  return ch_nr;
String icons(char input){
  String iconOutput;
  if (input == 0x01) iconOutput = "Audio_settings";
  if (input == 0x02) iconOutput = "Phone_settings";
  if (input == 0x03) iconOutput = "System_settings";
  if (input == 0x04) iconOutput = "Bluetooth";
  if (input == 0x05) iconOutput = "Default_settings";
  if (input == 0x12) iconOutput = "Music_note";
  if (input == 0x13) iconOutput = "Vehicle_phonebook";
  if (input == 0x14) iconOutput = "Mobile_phonebook";
  if (input == 0x15) iconOutput = "Call_history";
  if (input == 0x16) iconOutput = "Mail_box";
  if (input == 0x17) iconOutput = "Directory_management";
  if (input == 0x20) iconOutput = "Put_on_hold";
  if (input == 0x21) iconOutput = "USB";
  if (input == 0x24) iconOutput = "Volume";
  if (input == 0x25) iconOutput = "Ringtone";
  if (input == 0x26) iconOutput = "Cercle_empty";
  if (input == 0x27) iconOutput = "Cercle_full";
  if (input == 0x62) iconOutput = "Emergency";
  return iconOutput;
void gridSort3x2(bool counter){
  int arraySize = 6;
  String array3x2[arraySize];
  bool start_titles = false;
  bool counter_0x00 = false;
  int rowNr = 1;
  int columnNr = 1;
  int arrayPos = 0;
  int arrayElements = 0;
  char character;
  while (counter == false){
    if (mcp2515.readMessage(&canMsg) == MCP2515::ERROR_OK){
      if (canMsg.can_id == 1313 && canMsg.data[0] == 0x74){
        Serial.println("endOfMessage-1313");
        //Check how many strings are in the 3x3 array
        for (int i = 0; i < arraySize; i++){
          if (array3x2[i].length() > 0) arrayElements++;
        //Serial transmit the titles depending of number
        if (arrayElements == 3){
          //Insert below the 3 items identifier
          Serial.print("complex_grid1x2:");
          Serial.print(array3x2[2]);
          Serial.print(":");
          Serial.print(array3x2[5]);
          Serial.println(endString);
          return;
        if (arrayElements == 6){
          Serial.print("complex_grid3x2:");
          Serial.print(array3x2[1]);
          Serial.print(":");
          Serial.print(":");
          Serial.print(array3x2[3]);
          Serial.print(":");
          Serial.print(array3x2[4]);
          Serial.print(":");
          Serial.print(":");
          Serial.print(array3x2[6]);
          return;
    if (canMsg.can_id == 289 && canMsg.data[0] ==0x23){
      start_titles = true;
      Serial.println("Starting text reading");
    if (canMsg.can_id == 289 && start_titles == true){
      //Serial.println(arrayElements);
      for (int i=1; i<=7; i++){
          if (canMsg.data[i] == 0x0D){
            if (rowNr == 3){
              //rowNr = 1;
            }else rowNr++;
          if (canMsg.data[i] == 0x00 && i != 0){
            if (counter_0x00 == true){
              columnNr++;
              rowNr = 1;
            } else counter_0x00 = true;
          } else counter_0x00 = false;
          //Checking where on the 3x2 array whe are to save the string
          if (rowNr == 1 && columnNr == 1) arrayPos = 1;
          if (rowNr == 2 && columnNr == 1) arrayPos = 2;
          if (rowNr == 3 && columnNr == 1) arrayPos = 3;
          if (rowNr == 1 && columnNr == 2) arrayPos = 4;
          if (rowNr == 2 && columnNr == 2) arrayPos = 5;
          if (rowNr == 3 && columnNr == 2) arrayPos = 6;
          //Serial.println(arrayPos);
          //Saving the string on the coresponding 3x3 array position
          if (columnNr == 1){
              if (canMsg.data[i] <= 0x7F && canMsg.data[i] != 0x0D){
                //Save the icon name in the first array column
                array3x2[arrayPos] = icons(canMsg.data[i]);
            if (columnNr == 2){
              if (canMsg.data[i] >= 0x20 && canMsg.data[i] <= 0x7E){
              character = canMsg.data[i];
              array3x2[arrayPos].concat(character);
              Serial.print("columnNr:");
              Serial.print(columnNr);
              Serial.print("  rowNr:");
              Serial.print(rowNr);
              Serial.print(" arrayPos:");
              Serial.print(arrayPos);
              Serial.print(" Text:");
              Serial.println(array3x2[arrayPos]);
          //Saving the string on the coresponding 3x2 array position
void loop(){
    if(canMsg.can_id == 289){
      if (canMsg.data[0] == 0x10 && canMsg.data[2] == 0x25){
        Serial.println("Check1");
        if (canMsg.data[4] == 0x09){
          Serial.println("Check2");
          if (canMsg.data[6] == 0x40){
            Serial.println("Entered GridSort3x2");
            gridSort3x2(false);
            Serial.println("Exited GridSort3x2");
Below is the text that gets out. Pay attention that when it reaches arrayPos:6 it does not save the correct character, however, the "character" variable does have the correct character saved. Usually it goes further than the character "S", this time it stucked here.
Entered GridSort3x2
columnNr:2  rowNr:1 arrayPos:4 Text:A
columnNr:2  rowNr:1 arrayPos:4 Text:Au
columnNr:2  rowNr:1 arrayPos:4 Text:Aud
columnNr:2  rowNr:1 arrayPos:4 Text:Audi
columnNr:2  rowNr:1 arrayPos:4 Text:Audio
columnNr:2  rowNr:1 arrayPos:4 Text:Audio s
columnNr:2  rowNr:1 arrayPos:4 Text:Audio se
columnNr:2  rowNr:1 arrayPos:4 Text:Audio set
columnNr:2  rowNr:1 arrayPos:4 Text:Audio sett
columnNr:2  rowNr:1 arrayPos:4 Text:Audio setti
columnNr:2  rowNr:1 arrayPos:4 Text:Audio settin
columnNr:2  rowNr:1 arrayPos:4 Text:Audio setting
columnNr:2  rowNr:1 arrayPos:4 Text:Audio settings
columnNr:2  rowNr:2 arrayPos:5 Text:P
columnNr:2  rowNr:2 arrayPos:5 Text:Ph
columnNr:2  rowNr:2 arrayPos:5 Text:Pho
columnNr:2  rowNr:2 arrayPos:5 Text:Phon
columnNr:2  rowNr:2 arrayPos:5 Text:Phone
columnNr:2  rowNr:2 arrayPos:5 Text:Phone s
columnNr:2  rowNr:2 arrayPos:5 Text:Phone se
columnNr:2  rowNr:2 arrayPos:5 Text:Phone set
columnNr:2  rowNr:2 arrayPos:5 Text:Phone sett
columnNr:2  rowNr:2 arrayPos:5 Text:Phone setti
columnNr:2  rowNr:2 arrayPos:5 Text:Phone settin
columnNr:2  rowNr:2 arrayPos:5 Text:Phone setting
columnNr:2  rowNr:2 arrayPos:5 Text:Phone settings
columnNr:2  rowNr:3 arrayPos:6 Text:
289   53   S
Board?
Arduino Nano Chinese version
Hello,
Valid array indices are 0 to size - 1
http://www.cplusplus.com/doc/tutorial/arrays/
I don't know how I missed that. I think I wanted to start from 1 to be easyer to read the grid, and started from 1, forgeting about that. Thank you so much. This is the new feedback after some more debugging.
array position: 1   icon HEX:  1  --  Audio_settings
array position: 2   icon HEX:  2  --  Phone_settings
array position: 3   icon HEX:  3  --  System_settings
arrayelements=6
complex_grid3x2:Audio_settings:Phone_settings:System_settings:Audio settings:Phone settings:System settings:end_string
array position: 1   icon HEX:  2  --  Phone_settings
array position: 2   icon HEX:  3  --  System_settings
array position: 3   icon HEX:  4  --  Bluetooth
arrayelements=6
complex_grid3x2:Phone_settings:System_settings:Bluetooth:Phone settings:System settings:Bluetooth connection:end_string
array position: 1   icon HEX:  3  --  System_settings
array position: 2   icon HEX:  4  --  Bluetooth
array position: 3   icon HEX:  1  --  Audio_settings
arrayelements=6
complex_grid3x2:System_settings:Bluetooth:Audio_settings:System settings:Bluetooth connection:Audio settings:end_string
array position: 1   icon HEX:  4  --  Bluetooth
array position: 2   icon HEX:  1  --  Audio_settings
array position: 3   icon HEX:  2  --  Phone_settings
arrayelements=6
complex_grid3x2:Bluetooth:Audio_settings:Phone_settings:Bluetooth connection:Audio settings:Phone settings:end_string
arrayelements=6
arrayelements=6
arrayelements=6
arrayelements=6
