Strange code behaviour.
Hi. I´m trying to assign a colour to an RGB led throgh an hex number fed through a serial . I´ve been able to get the right values to do so. My problem is that the values of the ints I´m using change in a strange way.
I´m pretty sure the problem is in the control loops, but I cannot find it.
Thank you in advance.
This is my code
byte buffer[7];
int pointer=0;
byte inByte;
int r=0;
int g=0;
int b=0;
int Rled=9;
int Gled=10;
int Bled=11;
void setup(){
  pinMode(Rled,OUTPUT);
  pinMode(Gled,OUTPUT);
  pinMode(Bled,OUTPUT);
void loop(){
  if (Serial.available() > 0) {
	Serial.println("A");
        Serial.println(r);
        Serial.println(g);
        Serial.println(b);
    while(pointer<6){
            inByte = Serial.read();
            if(inByte=='#')pointer--;
            buffer[pointer]=inByte;
            pointer++;
         Serial.println("B");
         Serial.println(r);
         Serial.println(g);
         Serial.println(b);
           pointer=0;
            r =hex2dec(buffer[1])+hex2dec(buffer[0])*16;
            g=hex2dec(buffer[3])+hex2dec(buffer[2])*16;
            b= hex2dec(buffer[5])+ hex2dec(buffer[4])*16;
            Serial.println("C");
            Serial.println(r);
            Serial.println(g);
            Serial.println(b);
            color(r,g,b);
            delay(3000);
       }else{
         color(255,0,0);
  int hex2dec(byte c){
  if(c>='0'&&c<='9'){
      return c-'0';
    }else if(c>='A'&&c<='F'){
      return c-'A'+10;
  void color(int rojo,int verde, int azul){
  analogWrite(Rled,255-rojo);
  analogWrite(Gled,255-verde);
  analogWrite(Bled,255-azul);
This is an example
hex fed: #39FF5A. rgb value (57,255,90)
And this is the response
A
0
0
0
B
0
0
0
C
-1054
-1054
-1054
A
-1054
-1054
-1054
B
-1054
-1054
-1054
C
57
255
90
If you read bytes faster than they are being sent you will get -1 from Serial.read(). I suspect that you are trying to convert some -1 characters from hex to decimal but your conversion function doesn't handle that case.
You should either check for Serial.available() before EACH TIME you call Serial.read() or you should check for a -1 result from Serial.read().
You seem to be trying to read and write from the Serial at the same time.
If the first character you receive is a '#', you are going to try and write something at buffer[-1] , which is
never a good idea.
This is how I would do it:
void loop(){
  if (Serial.available()) {
    if(inByte=='#')
      pointer = 0;
    if ((inByte >= '0' && inByte <= '9') || (inByte >= 'A' && inByte <= 'F'))
      buffer[pointer++] = inByte;
    if (pointer == 6) { // Received a color
      pointer = 0; // Prepare for next time
      r = hex2dec(buffer[1]) + hex2dec(buffer[0])*16;
      g = hex2dec(buffer[3]) + hex2dec(buffer[2])*16;
      b = hex2dec(buffer[5]) + hex2dec(buffer[4])*16;
      Serial.println(r);
      Serial.println(g);
      Serial.println(b);
      color(r,g,b);
Thank you to all of you. That was really helpful
