Strange conflict between Virtualwire device and Onewire device
Have a solar inverter controller project thats been running for a year or so now, with a onewire dallas temp sensor working fine, reads around 20 to 40c normally. Uses dig pin 6.
I should add its a mega with an ethernet sheild.
Then I connected to it a 433hz reciever (virtualwire) via pin 11 to recieve temp data from another device. This also works fine but the temp data of the first device, the dallas temp sensor now goes all screwy, like -230c often or -70. Everything else still works normally.
I changed the dig pin of the dallas temp sensor to pin 7, to check it was not a pin conflict between it and anything else, which had no change.
If I edit out the vw_pll_start command line in setup, the problem goes away, but of course i cant get my data from the device transmitting as the reciever is not listening.
Ive read that virtualwire uses timer1 . I have been unable to find what onewire uses.
Does anyone know what could be happening?
I could post my codes if someone wants however i have huge codes as these are large projects and I wouldnt expect someone here to wade through pages of code.
The onewire and virvualwire standard library code examples were uses and embedded into the codes.
But glad to post the code if wanted.
Cheers and hopefully someone else who has had a project with both these devices incuded that has bumped into this issue may know whats happening?
#include <Wire.h>
#include "RTClib.h"
#include <LCD4Bit_mod.h>
#include <stdio.h>
#include <stdlib.h>
#include <VirtualWire.h>
LCD4Bit_mod lcd = LCD4Bit_mod(2);
#define tture1 2   // data line of DS18B20 sensor connected to D2
#define tture2 3
#define tture3 10
RTC_DS1307 RTC;
char Sensor1CharMsg[4];
int Sensor1Data, pumpon, solon, ct, tt, bt, x, h, m, w, d, adc_key_in; //initiate intergers,
//for pump state, ct temp and bt temp, and data from sensors, pushbuttons, and timing constants.
//int tankmax = 95;  // set maximin temp of top tank sensor
int diff = 12;   // initial differential, temp above bt temp that pump turns on
int pumpoffdelay = 20;
int HighByte, LowByte, TReading, SignBit, Tc_100, Whole, Ttemp, Fract, at;
const int pump = A1;   //define pin for pump relay
const int pumpLED = A2;      // define pin for LED output
const int sol = A3;   // define pin for overtemp water release solenoid
const int tmax = 75;  //max top tank temp set point for water solenoid to dump excess hot water
  Wire.begin();
  RTC.begin();
  // following line sets the RTC to the date & time this sketch was compiled
  RTC.adjust(DateTime(__DATE__, __TIME__));
  pinMode (pump, OUTPUT);  //set pins to output pump relay
  pinMode (pumpLED, OUTPUT); // sets LED pin to show pump is on
  pinMode (sol, OUTPUT);  // sets pin to output solenoid
  lcd.init();     //initiate display and setup standing display elements
  setupscreen();
  //For each tture sensor: Do a pinMode and a digitalWrite
  pinMode(tture1, INPUT);
  pinMode(tture2, INPUT);
  pinMode(tture3, INPUT);
  digitalWrite(tture1, LOW);//Disable internal pull-up.
  digitalWrite(tture2, LOW);
  digitalWrite(tture3, LOW);
  delay(100);
  // VirtualWire setup
 vw_setup(1000); // Bits per sec
void loop(){
  adc_key_in = analogRead(0);
  int hundreds = (tt*100); //round off top tank temperature into a whole int and send it to first two digits of the four digit string
  Sensor1Data = (hundreds+ct); //combine together to make four digit string
  itoa(Sensor1Data,Sensor1CharMsg,10); // send four digit string containing both temps
  w = w +1;
  //Serial.println(adc_key_in);    //was used for setting up buttons
  if (adc_key_in < 150) {   //if "UP" button is pressed, increment diff value up one.
    diff = diff + 1;
    delay(50);
  if ((adc_key_in > 300) && (adc_key_in < 350)) {    //if "DOWN" button is pressed, increment diff value down one.
    if (diff > 3) {          // diff value can not go below 3 (coz that'd be daft).
      diff = diff - 1;
      delay(50);
  if (diff < 10)  // this is just to keep the display neat if the diff is reduced back below 10
    lcd.cursorTo(1, 15);
    lcd.printIn(" ");
  delay(200);
  readTture(tture1);//N.B.: Values passed back in globals
  Serial.print("ct");
  ct = Whole;  // ct is collector temperature, used for pump operation calculations
  lcd.cursorTo(1, 2);  //top line cursor position 3
  printTture();//
  Serial.print("   ");
  delay(200);
  lcd.cursorTo(1, 9);
 Serial.print("tt");
  readTture(tture2);//Now read and report 2nd tture.
  tt = Whole;  // store this temperature value as current top tank temp
  printTture();
  delay(200);//
  Serial.print("  bt");//Start new line
  lcd.cursorTo(2, 2);  //line=2, x=0
  readTture(tture3);//N.B.: Values passed back in globals
  bt = Whole;  //bt is bottom tank temperature used for pump operation calculations
  printTture();//N.B.: Takes values from globals. Also...
  Serial.print("  ");
  if (pumpon == true) {
    Serial.print("PUMP ON");
  else {
    Serial.print("PUMP OFF");
  if (solon == true) {
    Serial.print(" SOL ON");
  else {
    Serial.print(" SOL OFF");
  Serial.print("  pump off delay is ");
  Serial.print(pumpoffdelay);
  Serial.print(" diff ");
  Serial.print(diff);
  //Serial.print("  "Ttemp);
  Serial.print("\n");
  // DEBUG radio
  //Serial.print("Sensor1 Integer: ");
  //Serial.print(Sensor1Data);
  //Serial.print(" Sensor1 CharMsg: ");
  //Serial.print(Sensor1CharMsg);
  //Serial.println(" ");
  //Serial.print(hundreds);
  //Serial.print("  ");
  delay(100);// Delay... must not be too short.
  x = x +1;
  if (x == 40) {
    vw_send((uint8_t *)Sensor1CharMsg, strlen(Sensor1CharMsg)); //send string to radio
 vw_wait_tx(); // Wait until the whole message is gone
    //at = (tt+bt)/2;  //calculates at average temperature  average temp of the whole tank
   // Ttemp = map(tt, 40, 80, 17, 10);
   // diff = constrain(Ttemp, 10, 17); //these two steps change the diff value so it is wide for a cool tank, narrow for hot tank, thereby
    // helping to maintain the tank around 65 degrees if the system gets too much sun
    DateTime now = RTC.now();
    Serial.print(now.hour(), DEC);
    Serial.print(':');
    if ( now.minute() < 10) {
      Serial.print("0");
    Serial.print(now.minute(), DEC);
    Serial.print(':');
    if (now.second() < 10) {
      Serial.print("0");
    Serial.print(now.second(), DEC);
    h = (now.hour());
    m = (now.minute());
    char timehour [33];
    char timemin [33];
    itoa (h,timehour,10);
    itoa (m,timemin,10);
    lcd.clear();
    lcd.cursorTo(1, 5);
    if (h < 10)  {
      lcd.printIn(" ");
    lcd.printIn(timehour);
    lcd.printIn(":");
    if (m < 10) {
      lcd.printIn("0");
    lcd.printIn(timemin);
   if (tt >= tmax) {  //turns on heat dump solenoid if temp of tank is above tmax deg c
     solon = true;
   else {
     solon = false;
    setupscreen();
    x = 0;
  if (ct > (tt + diff))  {
    pumpon = true;
    w = 0;
  else {
    if (w == pumpoffdelay) {    // this ensures that if the pump turns on, it STAYS on for 20 cycles (seconds)
      pumpon = false;
      w = 0;
  if (w == 101) {
    w = 0;
  if (pumpon == false) {
    lcd.cursorTo(2, 13);
    lcd.printIn("OFF");
    digitalWrite (pump, LOW);
    digitalWrite (pumpLED, LOW);
    lcd.printIn("ON ");
    digitalWrite (pump, HIGH);
    digitalWrite (pumpLED, HIGH);
    digitalWrite (sol, HIGH);
  if (solon == false) {
    digitalWrite (sol, LOW);
void OneWireReset(int Pin) // reset.  Should improve to act as a presence pulse
  digitalWrite(Pin, LOW);
  pinMode(Pin, OUTPUT); // bring low for 500 us
  delayMicroseconds(400);
  pinMode(Pin, INPUT);
}//end OneWireReset
void OneWireOutByte(int Pin, byte d) // output byte d (least sig bit first).
  byte n;
  for(n=8; n!=0; n--)
    if ((d & 0x01) == 1)  // test least sig bit
      delayMicroseconds(5);
      delayMicroseconds(60);
    d=d>>1; // now the next bit is in the least sig bit position.
}//end OneWireOutByte
byte OneWireInByte(int Pin) // read byte, least sig byte first
  byte d, n, b;
  for (n=0; n<8; n++)
    b = digitalRead(Pin);
    delayMicroseconds(50);
    d = (d >> 1) | (b<<7); // shift d to right and insert b in most sig bit position
  return(d);
}//end OneWireInByte
void readTture(byte Pin){
  //Pass WHICH pin you want to read in "Pin"
  //Returns values in... (See global declarations)
  OneWireReset(Pin);
  OneWireOutByte(Pin, 0xcc);
  OneWireOutByte(Pin, 0x44);
  OneWireReset(Pin);
  OneWireOutByte(Pin, 0xbe);
  LowByte = OneWireInByte(Pin);
  HighByte = OneWireInByte(Pin);
  TReading = (HighByte << 8) + LowByte;
  SignBit = TReading & 0x8000;  // test most sig bit
  if (SignBit) // negative
    TReading = (TReading ^ 0xffff) + 1; // 2's comp
  Tc_100 = (6 * TReading) + TReading / 4;    // multiply by (100 * 0.0625) or 6.25
  Whole = Tc_100 / 100;  // separate off the whole and fractional portions
  Fract = Tc_100 % 100;
};//end readTture
void printTture(){
  //N.B.: No new line inside printTture
  if (SignBit) // If it's negative
    Serial.print("-");
  Serial.print(Whole);
  Serial.print(".");
  if (Fract < 10)
    Serial.print("0");
  Serial.print(Fract);
  char temp [33];
  char D [33];
  char Dec [10];
  itoa (Whole,temp,10);
  itoa (diff,D,10);
  d = floor (Fract/10);
  itoa (d,Dec,10);
  lcd.printIn(temp);
  lcd.printIn(".");
  lcd.printIn(Dec);
  lcd.cursorTo(1, 14);
  if (diff<10) {
    lcd.printIn("0");
  lcd.printIn(D);
void setupscreen(){
  lcd.clear();    // clears display
  lcd.printIn("CT    c");
  lcd.cursorTo(2, 0);
  lcd.printIn("BT    c");
  lcd.cursorTo(1, 7);
  lcd.printIn("TT    c");
  lcd.cursorTo(2, 8);
  lcd.printIn("Pump");
That was the transmitter code.
Id put the reciever code here but its too big. Maybe I could chop a unimportant bit out.
Any luck solving this?
I have the same problem.
A Mega 2560
Using 433hz reciever (virtualwire) via pin 3 AND OneWire DS18B20 via pin 2.
When I comment out this line:
vw_rx_start();
the DS18B20 is recognized properly.
When this line is enabled, than it is not.
I feel newbie in this. Have no knowledge to go deep into this libs.
edit: Eureka! I needed to switch the positions of code for VW and OW.
So in my setup() I was having (my functions that covers all the initial stuff)
initRadioReciever();
initWireThermometer();
switching them did the trick, so:
Still, I get the same problem that sometimes the values goes crazy in that setup.
Cheers,
Timing for the OneWire functions is critical in a few places, and it is possible that interrupts are disrupting that timing.
You might try enabling and disabling VirtualWire (or just interrupts) when checking the temperature.
I have solution.
Have downloaded leatest Version of OneWire (2.2) from OneWire Arduino Library, connecting 1-wire devices (DS18S20, etc) to Teensy
Mine was very old, like 1.0 or so.
Had to change the code a bit to meet new library requirements.
And voila, there is no conflict right now. Hope it will help others as well
