This topic could be a continuation of this one...
https://forum.arduino.cc/t/arduino-nano-web-server-ajax-not-quite-working/1342359
... but that one was resolved. I have built on on that sketch with some added functionality and have new issues, so here's a new topic.
So we have an Arduino Nano with a web server. I want my Arduino to retrieve some measurements from another ATMega controller over I2C, present those data on a webpage and send them continually over Ethernet to a PC for visualisation (Grafana). Here is the code:
#include <SPI.h>
#include <EthernetENC.h>
//#include <Wire.h>
#define pAI03 A3
#define pAI06 A6
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0x47 };
IPAddress ip(192, 168, 1, 71);
EthernetServer server(6501);
EthernetUDP udp;
const byte MY_ADDRESS = 11;
String HTTP_req;
int g = 0;
int i = 0;
int i22AI03, i22AI06 = 0;
String s22AI03, s22AI06;
String vIED_22;
Ethernet.begin(mac, ip);
server.begin();
//Wire.begin(MY_ADDRESS);
pinMode(pAI03, INPUT);
pinMode(pAI06, INPUT);
analogReference(DEFAULT);
TCCR1A = B00000000;
TCCR1B = B00001101;
OCR1A = 15625;
TIMSK1 = B00000010;
if (client)
boolean currentLineIsBlank = true;
while (client.connected())
if (client.available())
char c = client.read();
HTTP_req += c;
if (c == '\n' && currentLineIsBlank)
client.print(F("HTTP/1.1 200 OK\r\nContent-Type: text/html\r\nConnection: close\r\n\r\n"));
if (HTTP_req.startsWith("GET /ajax_switch"))
GetSwitchState(client);
client.print(F(R"~~~(
<!DOCTYPE html>
<html>
<head>
<title>Arduino Web Page</title>
<script>
function GetSwitchState()
var nocache = "nocache=" + Math.random() * 1000000;
var request = new XMLHttpRequest();
request.onreadystatechange = function()
if (this.readyState == 4)
if (this.status == 200)
if (this.responseText != null)
document.getElementById("switch_txt").innerHTML = this.responseText;
request.open("GET", "ajax_switch?" + nocache, true);
request.send(null);
setTimeout(GetSwitchState, 1000);
</script>
</head>
<body onload="GetSwitchState()">
<h1>Weather Station</h1>
<div id="switch_txt">Starting...</div>
</body>
</html>
HTTP_req = "";
if (c == '\n')
else if (c != '\r')
currentLineIsBlank = false;
delay(1);
client.stop();
if (g == 1)
g--;
s22AI03 = String(i22AI03);
s22AI06 = String(i22AI06);
vIED_22 = String("IED_22 22AI03=" + s22AI03 + ",22AI06=" + s22AI06);
Serial.println(vIED_22);
void GetSwitchState(EthernetClient cl)
i++;
cl.print("Counter = ");
cl.print(i);
cl.print("<br>22AI03 = ");
cl.print(i22AI03);
cl.print("<br>22AI06 = ");
cl.print(i22AI06);
ISR(TIMER1_COMPA_vect)
g++;
i22AI03 = analogRead(pAI03);
i22AI06 = analogRead(pAI06);
For now I am not using I2C but reading two potentiometers connected to Arduino. If I don't use Wire.h and don't initiate I2C (wire.begin()) everything works fine. However, if I uncomment those two lines here is what happens: the programs works fine until I refresh the web page. After that still everything works except for this line:
What happens is that the string that is created omits everything before the comma. So if I don't include the "22AI06" part then an empty string is created. Otherwise the string looks like this:
,22AI06=517
Other than that, everything else works fine, including the I2C communication and sending data to the PC which I omitted here in order to focus on the part that doesn't work.
To summarize: everything works fine until I refresh the webpage, after which the creation of the string "vIED_22" doesn't work as it should. And all this only if Wire.h is included. Is it a conflict between libraries? Or something simpler?
