strange corruption with "while (!Serial);" on Arduino Micro
Stock Arduino Micro, a 7-segment display with a backpack, and assorted libraries. The goal is to make a clock that goes into a CD-ROM bay in a PC and display the PC time. The Arduino runs its own time base, gets synced from the PC over USB once in a while.
This is the sketch:
 *  Sync time from PC source over serial
 *  and show it on 7-segment LED display
#include <Wire.h>
#include "Adafruit_LEDBackpack.h"
#include "Adafruit_GFX.h"
#include <Time.h>
#include <TimeAlarms.h>
#define TIME_HEADER  "T"   // Header tag for serial time sync message
//#define TIME_REQUEST  7    // ASCII bell character requests a time sync message
Adafruit_7segment matrix = Adafruit_7segment();
const unsigned long DEFAULT_TIME = 1357041600;
  pinMode(13, OUTPUT);
  matrix.begin(0x70);
  // fake time
  setTime(DEFAULT_TIME);
  Alarm.timerRepeat(1, showTime);
//  while (!Serial);
  setSyncProvider(requestSync);
  if (Serial.available()) {
    processSyncMessage();
//  showTime();
//  delay(1000);
  Alarm.delay(1000);
void showTime() {
  uint16_t timestr = 100 * hourFormat12() + minute();
  byte tick = (second() + 1) % 2;
  matrix.println(timestr);
  matrix.writeDigitRaw(2, 2 * tick);
  matrix.writeDisplay();
  digitalWrite(13, tick);
void processSyncMessage() {
  unsigned long pctime;
  if(Serial.find(TIME_HEADER)) {
     pctime = Serial.parseInt();
     if( pctime >= DEFAULT_TIME) { // check the integer is a valid time (greater than Jan 1 2013)
       setTime(pctime); // Sync Arduino clock to the time received on the serial port
time_t requestSync() {
//  Serial.write(TIME_REQUEST);
  return 0;
I could display time either using alarms (TimeAlarm.h), or plain old delays. As shown above, the code uses delays alarms, but the behavior is the same anyway.
To sync it up, I run this code on Linux:
#!/bin/bash
port="/dev/ttyACM0"
utc=`date +%s`
tz=`date +%:::z`
ltime=$(($utc + $tz * 3600))
echo "T${ltime}" > $port
If I uncomment the “while (!Serial);” line in the Arduino sketch, all hell breaks loose. The code often won’t start; the display is frozen in whatever was the last state. Or it displays random segments on the display, as if it crashed. I reset the Arduino and nothing happens. After much reuploading and resetting, it eventually takes off, but that only lasts until the next reset. Many portions of the sketch are commented out, but the crash-and-freeze happens even with those parts added back in.
Once I commented out that line, the sketch works great.
Seeing as the line is probably not needed, I’ll remove it permanently, but I’d like to understand why it fails like this so badly. Freezing - okay, that makes sense, maybe USB is not ready or something, but the total crashes where the display is corrupted???
The Micro is connected on USB to a laptop running Ubuntu 13.04.
The Micro and the display are probably okay. If I upload the “sevenseg” example that comes with the Backpack library, everything is running just fine.
but I'd like to understand why it fails like this so badly.
I'd like to understand why you included the line. All the samples that have that line CLEARLY indicate that it is needed ONLY for the Leonardo.
Don't agree with that, PaulS.
See this page:
(This is linked to from the Micro product page).
On that:
No reset when you open the serial port.
Unlike the Arduino Uno, the Leonardo and Micro won't restart your sketch when you open a serial port on the computer. That means you won't see serial data that's already been sent to the computer by the board, including, for example, most data sent in the setup() function.
This change means that if you're using any Serial print(), println() or write() statments in your setup, they won't show up when you open the serial monitor. To work around this, you can check to see if the serial port is open like so:
// while the serial stream is not open, do nothing:
while (!Serial) ;
**Separation of USB and serial communication.**
On the Leonardo and Micro, the main Serial class refers to the virtual serial driver on the board for connection to your computer over USB. It's not connected to the physical pins 0 and 1 as it is on the Uno and earlier boards. To use the hardware serial port (pins 0 and 1, RX and TX), use Serial1. (See the Serial reference pages for more information.)
It clearly mentions the Micro there.
So he's done the right thing, and that line shouldn't fail.
@Florin_Andrei - what version of the IDE do you have?
Please use code tags for code next time, not quotes or the "copy for forum" function in the IDE.
Read this before posting a programming question
[quote author=Nick Gammon link=topic=181466.msg1345101#msg1345101 date=1375845385]
@Florin_Andrei - what version of the IDE do you have?[/quote]
Latest - 1.5.2. I share the sketchbook folder via Dropbox between Windows 7 and Ubuntu Linux 13.04 and I run the IDE on either computer. But it's mostly on Linux that I do my breadboard testing.
I will try different speeds for Serial.begin(), maybe that makes a difference. Again, it's no excuse for the nasty corruption, but maybe it's an enabling factor somehow.
Another weird thing: have you noticed I use hourFormat12() instead of hour()? Yeah, that's because the 24-hour function displays nothing at all. Even if I change the code from...
...to...
uint16_t timestr = hour();
...so that only the hour is shown, all I get is a blank.
It's almost as if there's some subtle issue with one of the libraries, or something. I need to do more testing. I'll also try to bring this thread to the attention of the library authors, hopefully I won't waste their time.
I actually use the time library from pjrc: Time Library, Timekeeping and Time/Date Manipulation on Teensy
Apologies for making a mess, I fixed it.
I've downgraded from 1.5.2 (beta) to 1.0.5 (stable). Same issues.
I've reduced the sketch to the minimal size that still demonstrates the problem:
//  while (!Serial);
  digitalWrite(13, 1);
  delay(100);
  digitalWrite(13, 0);
  delay(100);
This version works fine. If I uncomment the "while (!Serial);" line, it freezes. Comment it back out, and it starts blinking again.
I've changed the serial speed to 115200 - same symptoms.
Again, this is on an Arduino Micro, connected via USB to a laptop running Ubuntu Linux 13.04 64bit.
I tried this on my Micro. I’m have IDE 1.05 on a Mac. The sketch stays stuck in the while loop until I open my serial monitor, it’s not ‘freezing’. Then exits the while loop and moves on. I ran the sketch below and the LED blinks slowly until I open my serial monitor then it blinks fast.
  do {
  } while (!Serial);
  delay(100);
  delay(100);
On my Leonardo I usually use this code so it only loops for 8 seconds and then moves on:
while (!Serial && millis() < 8000) {}
