Strange debouncing behavior
Ok, first of all I will apologize as I have been a lurker here without an account since 2013 when I got my first Arduino. Since then almost all of my questions have been answered by searching this and other forums and tutorials. That being said I am now having an issue that I cannot seem to explain.
I am horrible at coding so I apologize how clunky my sketch is and if this is a reason for my problem please point out where.
I am making a DMX controller using a MAX485 breakout to control lights in a small private theater when we don't feel like taking out the big 144 channel control desk.
I am building a small box with 5 buttons and 6 LEDs to be able to choose from 7 basic options
Options one through 3 = House Lights at either Full, Half or Out
Options 4 through 7 = Stage Lights for Presentation, Video, Band or OFF
It is set up such that
button1 controls house to either full or half
button2 is presentation
button3 is video
button4 is band
button5 is House out
I have stripped out all of my DMX code so that I can use Serial since the DMX uses the TX and RX lines.
For some reason intermittently the code seems to be ignoring the fixed debounce delay and flashing the chosen scene on and off faster than the debounce should allow. I have my debounce delay set at 1000ms and I am seeing my previous time of only 84s and it is changing again even without the button being pressed. if I press it again it stops flashing and behaves for a while till this glitch seems to happen randomly again
here is my code, I think I put it here appropriately. again I apologize I am not very good at writing sketches.
/*Trial sketch for debugging
int button1 = 3; //Scene1 - House on/half  -  Red Buton
int button2 = 4; //Scene2 - Speaker
int button3 = 5; //Scene3 - Speaker w/video
int button4 = 6; //Scene4 - Band
int button5 = 7; //Scene5 - House OUT
int led1 = 8; //Scene1 - On Green
int ledH = 9; //Scene1 - Half Yellow
int led2 = 10; //Scene2 Green
int led3 = 11; //Scene3 Green
int led4 = 12; //Scene4 Green
int led5 = 13; //Scene5 Blue
//one additional LED directly between VCC and GND as power indicator
bool sceneH = true;
bool scene2 = false;
bool scene3 = false;
bool scene4 = false;
bool scene5 = false;
unsigned long debounce = 1000; //This is the debounce delay make longer if engagement is unreliable
unsigned long t1 = 0;
unsigned long t2 = 0;
unsigned long t3 = 0;
unsigned long t4 = 0;
unsigned long t5 = 0;
unsigned long lt1 = 0;
unsigned long lt2 = 0;
unsigned long lt3 = 0;
unsigned long lt4 = 0;
unsigned long lt5 = 0;
  Serial.println("Startup");
  //Set Modes for pins
  pinMode(button1, INPUT);
  pinMode(button2, INPUT);
  pinMode(button3, INPUT);
  pinMode(button4, INPUT);
  pinMode(button5, INPUT);
  pinMode(led1, OUTPUT);
  pinMode(ledH, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
  pinMode(led4, OUTPUT);
  pinMode(led5, OUTPUT);
  Serial.println("modes established");
  //Use LED5 as indicator of power on progress beginning
  digitalWrite (led5, HIGH);
  delay(100);
  digitalWrite (led1, HIGH);
  delay(10);
  digitalWrite (led2, HIGH);
  delay(10);
  digitalWrite (led3, HIGH);
  delay(10);
  digitalWrite (led4, HIGH);
  delay(10);
  digitalWrite (ledH, HIGH);
  delay(100);
  digitalWrite (led1, LOW);
  digitalWrite (led2, LOW);
  digitalWrite (led3, LOW);
  digitalWrite (led4, LOW);
  digitalWrite (ledH, LOW);
  delay(10);
  Serial.println("Startup Complete");
  house();
  bool state1 = digitalRead(button1);
  bool state2 = digitalRead(button2);
  bool state3 = digitalRead(button3);
  bool state4 = digitalRead(button4);
  bool state5 = digitalRead(button5);
  Serial.print(state1);
  Serial.print(lt1);
  Serial.print(" , ");
  Serial.print(state2);
  Serial.print(lt2);
  Serial.print(state3);
  Serial.print(lt3);
  Serial.print(state4);
  Serial.print(lt4);
  Serial.print(state5);
  Serial.print(lt5);
   if (state1 == HIGH){
    t1 = millis();
   if (state2 == HIGH){
    t2 = millis();
   if (state3 == HIGH){
    t3 = millis();
   if (state4 == HIGH){
    t4 = millis();
   if (state5 == HIGH){
    t5 = millis();
   if ((t1-lt1)>debounce){
    sceneH = !sceneH;
    house();
    lt1 = millis();
    Serial.print("House-");
    Serial.println(sceneH);
    delay(10);
   if ((t2-lt2)>debounce && t2>t3 && t2>t4){
    scene2 = !scene2;
    scene3 = false;
    scene4 = false;
    stage();
    lt2 = millis();
    Serial.print("Scene2-");
    Serial.println(scene2);
   if ((t3-lt3)>debounce && t3>t2 && t3>t4){
    scene3 = !scene3;
    scene4 = false;
    scene2 = false;
    stage();
    lt3 = millis();
   if ((t4-lt4)>debounce && t4>t2 && t4>t3){
    scene4 = !scene4;
    scene2 = false;
    scene3 = false;
    stage();
    lt4 = millis();
   if ((t5-lt5)>debounce){
    scene5 = !scene5;
    house();
    lt5 = millis();
   Serial.println("End Of Loop");
//-------------------Subroutine for Stage-----------------------
void stage(){
   //-----Scene 2 Presentation No Video
  if (scene2 == true) { //engage dimmers for Scene2 and write all other dimmers other dimmers to 0
    digitalWrite(led2, LOW);
    delay(100);
    digitalWrite(led2, HIGH);
    scene3 = false;
    digitalWrite(led3, LOW);
    scene4 = false;
    digitalWrite(led4, LOW);
    Serial.println("Presentation");
   //-----Scene 3 Presentation WITH Video
  if (scene3 == true) { //engage dimmers for Scene3 and write all other dimmers other dimmers to 0
    digitalWrite(led3, HIGH);
    delay(100);
    scene2 = false;
    scene4 = false;
    Serial.println("Video");
  //-----Scene 4 Band
  if (scene4 == true) { //engage dimmers for Scene4 and write all other dimmers other dimmers to 0
    delay(10);
    digitalWrite(led4, HIGH);
    scene2 = false;
    scene3 = false;
    Serial.println("BAND");
  if (scene4 == false && scene3 == false && scene2 == false) {
  // if no scenes are engaged then kill the stage lights
  Serial.println("No Stage Cue");
//------------------End Stage----------------------------------------
//-------------------Subroutine for House Lights--------------------
void house(){
  //-----HOUSE FULL
  if (sceneH == true) {
    digitalWrite(led1, HIGH); // digital writes are just controlling LEDs for indicators
    digitalWrite(ledH, LOW);
    digitalWrite(led5, LOW);
    Serial.println("House Full");
    scene5 = false;
  //-----House Lights To Half
  if (sceneH == false && scene5 == false) {
    digitalWrite(led1, LOW); // digital writes are just controlling LEDs for indicators
    digitalWrite(ledH, HIGH);
    Serial.println("House at Half");
  //-----House OUT
  if (scene5 == true && sceneH == false){
    //Turn house lights off
    digitalWrite(led5, HIGH);
    delay(10);
    delay(10);
    Serial.println("HOUSE OUT");
//----------End House Lights---------------------------
How are your buttons wired up? The code demands that they have external pull-up resistors to function properly. Are those pull-up reistors present?
As an alternative, you might want to check out the State Change Detection example since you really want to react when a button changes state, not based on the current state.
There also seems to be a lot of intermixed logic which (at first glance) is difficult to follow. Separating things may make it more clear.
consider
// recognize multiple button presses; tgl LED when pressed
#define ON  LOW
#define OFF HIGH
byte butPins [] = { A1, A2, A3 };
byte ledPins [] = { 10, 11, 12 };
#define N_PINS sizeof(butPins)
byte butLst [N_PINS] = {};
void setup (void)
    for (unsigned n = 0; n < N_PINS; n++)  {
        digitalWrite (ledPins [n], OFF);
        pinMode      (ledPins [n], OUTPUT);
        pinMode      (butPins [n], INPUT_PULLUP);
        butLst [n]  = digitalRead (butPins [n]);
void loop (void)
        byte but = digitalRead (butPins [n]);
        if (butLst [n] != but)  {
            butLst [n] = but;
            if (LOW == but)     // button pressed
                digitalWrite (ledPins [n], ! digitalRead (ledPins [n]));
    delay (10);         // debounce
Actually the buttons are configured with an external pull-down resistor and the pin goes high when button is depressed. I have run the digital read to serial on every button they are operating correctly and giving proper solid response. my question is why is the code allowing the state of a scene to change if the tX-ltX which is current time in millis minus last change time in millis to be less than the debounce constant?
And I understand I could write the code in other ways but to be honest I don't understand arrays well enough to use them, and in the end there will be a whole lot more code going into those subroutines related to the DMX signals those each will send.
funinalaska:
A one second debounce delay? That would be frustrating to use!
aarg:
It is specific to this application. If you turn on 10k or 100k watts of lights you don't want to turn them off too fast.
the length of the debounce is mainly to stop from accidental strobing.
Okay. I find your logic too weird to read the whole thing, but if you require such a long debounce delay, it is especially important to register the switch event immediately so that the buttons won't appear to be inoperative.
