Hi guys,
I got a strange behavior on a display trying to print some point dataset on a chart:
I m using UNO R3 and a ili9341 spi 240X320 TFT. I use to it and it is working fine with a derived from the Adafruit_GFX library.
I got a matrix with 24 rows and 2 columns presumably recording temperature and humidity but for the example I will put random numbers.
when I display the data, it looks like the humidity one (array [k][0]) is ''moving 2 time faster'' than the temperature one (array [k][1]): a bite like if my k is doing 2 iterations for that line the( k and k+1).. thus what is even more strange is that it affect the ''x'' coordinate which is rather fixed by (240 + 20) - (10 * k).
in the line: tft.drawCircle( (240 + 20) - (10 * k), (180 - (tempHistory[k][0] - 50) ), 2, BLUE);
if you replace the(180 - (tempHistory[k][0] - 50) ) by [k][1] everything is working fine .... really strange !
is anyone able to reproduce the bug?
Is somebody see something strange in that loop?
here the full code, and enclosed the full project .. you just need an TFT screen to tell me if you got the bug or not!!
thx for any help, it get me crazy!
#include "TFT_ILI9341.h"
#include <SPI.h>
#include <Wire.h>
#define TFT_CS 5 // 10
#define TFT_RST 4// 8 // you can also connect this to the Arduino reset in which case, set this #define pin to 0!
#define TFT_DC 6 //9
#define TFT_LED 10
//#define TFT_SCLK 13
//#define TFT_MOSI 11
#define BLACK 0x0000 // color code: http://www.rinkydinkelectronics.com/calc_rgb565.php
#define BLUE 0x001F // or http://www.barth-dev.de/online/rgb565-color-picker/
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#define LBLUE 0x7639
#define GRASS 0x2D08
#define GREENTREE 0x1A64
#define BROWNTREE 0x7203
#define GREY 0xD6BA
#define DARKGREY 0x9CD3
#define DESERT 0xF6CA
#define ORANGE 0xF343
//Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_RST);
TFT_ILI9341 tft = TFT_ILI9341();
byte max_Y;
int max_X;
unsigned long currentMillis;
unsigned long previousMillis;
const byte Arrayl = 24 ; // row ...
const byte ArrayC = 2; // column
float tempHistory[Arrayl][ArrayC] ;
tft.begin();
tft.setRotation(3); //rotation de l ecran: 0,1,2,3
max_Y = tft.height();
max_X = tft.width();
Wire.begin(); // initialization port I2C ->RTC module
//#################### fill the array with 0 everywhere #########################
for (byte i = 0; i < Arrayl; i++) {
for (byte j = 0; j < ArrayC; j++) {
tempHistory[i][j] = 0;
//#########################" background screen for the chart graph ###################"
tft.fillScreen(LBLUE);
tft.setTextColor(YELLOW);
tft.setCursor (65, 15);
tft.setTextFont(1);
tft.setTextSize(3);
tft.print("chart");
tft.drawRect(20, 50, 2, 150, BLACK);
tft.drawRect(20, 200, 240, 2, BLACK);
//drawn the ticks///////////
byte j = 1;
for (int i = 250; i >= 20; i -= 10) {
tft.drawRect(i, 200, 2, 5, BLACK);
if ((j % 2) == 0) {
tft.drawRect(i, 200, 2, 8, BLACK);
tft.setTextFont(1);
tft.setTextSize(1);
tft.setCursor (i - 3, 210);
tft.print(j);
j++;
currentMillis = millis();
if ((currentMillis - previousMillis) > 5000) {
//move the array number downward to be able to allocate more recent data
for ( int k = 0; k < ArrayC; k++) {
for (int j = Arrayl - 1; j >= 1; j--) {
tempHistory[j][k] = tempHistory[j - 1][k];
tempHistory[j][0] = tempHistory[j - 1][0];
//put some new random number in the array at [0][1] and [0][0] location
tempHistory[0][1] = random(0, 30);
tempHistory[0][0] = random(50, 90);
tft.fillRect(20 + 2, 50, 240 + 20, 150, LBLUE);
tft.fillRect(260, 13, 50, 40, LBLUE);
//display last value set in tempHistory[0][1]
tft.setCursor (260, 15);
tft.setTextColor(WHITE);
tft.setTextFont(1);
tft.setTextSize(2);
tft.print(tempHistory[0][1], 1);
tft.setTextSize(1);
tft.print(("C "));
//display last value set in tempHistory[0][0]
tft.setTextSize(2);
tft.setCursor (265, 35);
tft.print(tempHistory[0][0], 0);
tft.setTextSize(1);
tft.println(("%"));
//make the chart
for ( int k = 0; k < Arrayl; k++) {
// array [k][1] no problem during the display
tft.drawCircle( (240 + 20) - (10 * k), (180 - (tempHistory[k][1] - 0)), 2, RED);
tft.setCursor (((240 + 20) - (10 * k) - 6), (180 - (tempHistory[k][1] - 0)));
tft.setTextColor(RED);
tft.print(k);
// array [k][0] problem during the display!! move in the X dimension 2 way faster than it should thus value looks repeated
tft.setCursor (((240 + 20) - (10 * k) - 6),(180- (tempHistory[k][0] - 50)));
tft.print(k);
