When I try uploading any sketch to my board I get this error:
Using Port : /dev/cu.usbmodem142201
Using Programmer : wiring
Overriding Baud Rate : 115200
-avrdude: ser_open(): can't open device "/dev/cu.usbmodem142201": Resource busy
-ioctl("TIOCMGET"): Inappropriate ioctl for device
This error only appeared after I tried using cvzone and trying to send data from python over to Arduino for a project I'm working on. Before that my board worked perfectly fine. I've shut up down and restarted my laptop, closed all other windows and apps running other than Arduino IDE. I tried using the example blink sketch to over ride my previous sketches. I grounded the RX pin to reset the boards memory. I tried everything and nothing seems to work. Any help would be appreciated. Thank you.
