#include "capteur.h"
Led my_led();
SerialUSB.begin(115200);
while (!SerialUSB) ;
SerialUSB.println("Setup");
In my ino file if I do a
Led my_led();
it's work but if I do a
Led my_led(1);
it's doesn't work everything compiled but when I put the code in my bord I've nerver got here message in my console (setup or here messages) and I got an error with the ide I loss the connexion with the board "error when open port" I must reset the board, and put the code without parameters in my constructor, anyone know why? I really don't understand the code is really simple
No, no pin I just try to use c++ class, I got the same error if I put 1, 2 or 10. But it's works if I create my object in my setup function (with and without parameters).
Why I can't create my object before setup function ??
Led* my_led; // A pointer to your object.
my_led = new Led(13); // Dynamically create the class (at the correct time)
Global object constructors are called before setup() so before your Serial.begin(). That might explain why you can't use Serial.print() in the constructor of a global object. That is also why a lot of library objects have a .begin() function. The Arduino core is not initialized until just before setup() is called and millis(), micros(), delay(), Serial... won't work until the core is initialized.
