strange error
when i hit verify on the ide i get a strange error with one particular program. i have seen this error elsewhere on the boards but the fixes suggested havnt worked for me. here is the error:
C:\Users\Owner\AppData\Local\Temp\build6619.tmp\core.a(wiring_serial.c.o): In function `__vector_18':
C:\Users\Owner\Desktop\arduino-0015\hardware\cores\arduino/wiring_serial.c:112: multiple definition of `__vector_18'
C:\Users\Owner\AppData\Local\Temp\build6619.tmp\core.a(HardwareSerial.cpp.o):C:\Users\Owner\Desktop\arduino-0015\hardware\cores\arduino/HardwareSerial.cpp:95: first defined here
Couldn't determine program size: C:\Users\Owner\Desktop\arduino-0015\hardware/tools/avr/bin/avr-size: 'C:\Users\Owner\AppData\Local\Temp\build6619.tmp\sketch_090519c.hex': No such file
a few people were saying in other threads that it could likely be an error in the program stopping the program from compiling and therefore causing the unknown size error at the bottom, but i dont think this is the cause. ill include the code anyway
int pin1 = 2;
int serialIn;
void setup ()
  pinMode(pin1,OUTPUT);
void loop ()
  serialIn = serialRead();
  if (serialIn = 49)
    digitalWrite (pin1,HIGH);
I am running Windows Vista Intel Core 2 duo 1.66 GHz. any help would be greatly appreciated
EDIT: problem solved, it was a syntax error (shame on me). Thanks for the quick replies and help
What files are in the Sketch directory?
  • Brian
Hi MrAndrews,
Inside the loop function your are calling
but function serialRead happens to be the name of an internal function of the basic Arduino-source files. This function was not intened to be called from Sketches like yours, but there is also no way to prevent it to happen by accident :-(
But this is just a short explanation why the error is reported. The solution is simple :
Use the function Serial.read()
  serialIn = Serial.read();
Yes, the same characters but in different case and a dot in the middle, a bit confusing when you just started with programming. But this really is a totally different function, and the one you should use in your sketches. http://arduino.cc/en/Serial/Read
Eberhard
i think you mean to do if(serialIn == 49) instead of if(serialIn = 49)
@Wayoda, thanks so much for the help. i was actually meaning to use the built in function Serial.read but didnt realize my mistake when i was debugging. iv fixed the error and it works fine now
