cowasaki:
I have just reduced the size of the text strings by 600 bytes and hey presto it all works perfectly, then logged back in and read dc42's post (great minds etc)!!
Glad you got it working. The 328p only has 2KB of RAM for static data, strings, stack and any dynamic memory you allocate; and 600 bytes is quite a large chunk of that.
It saved you nearly 1/2k of ROM. If you're using only half of your ROM, that isn't such a big deal.
Your problem is that all those long strings are using up RAM, as I pointed out earlier.
String literals enclosed in PSTR() are held in program space instead of RAM; but you can't pass them to Serial.print directly, so you print them with serialPrint_P instead. The amount of RAM you need for these strings is about the length of the longest string you print in this way, instead of the total length of all the strings.
Sorry but I am an experienced programmer but not particularly with this language. I would have thought that the above line would be a constant and therefore not use up variable space.
My understanding might be completely wrong though!
Yes, that's what I thought.
I thought (as per above post) that serial.print('xxxxxx'); wouldn't use ram
I'm a little confused as to why I am getting the problem that I am. I am using only a few global variables and a few local ones. I am also stashing away a number of values in EEPROM.
Well, not so much a variable as something that occupies RAM.
Consider the "println" method.
It has a overload that takes a "char*".
"char*" can only sensibly point to RAM.
I would expect the serial.println function to use a small amount of ram whilst it us doing it's thing but then release it afterwards. I wouldn't expect it to keep that ram.
Why would it?
I am not questioning anybody, I'm just confused as to why it would
Why? The function call can be in ROM transferring the value to RAM for the call. It seems a strange thing to do to store all function call CONSTANTS in RAM.
Oh well if it does it does but it still sound daft.
The function call IS in ROM - all the code is in ROM.
This is Harvard architecture processor, not von Neumann.
It would make more sense to send the ROM address
Consider:
char string [] = "Where do I put this?";
Serial.println (string);
Serial.println("And where should I put this and distinguish it from the other one?");
Consider:
I appreciate what you are saying and do understand. I am just expecting more from it than it does! I will look at the examples earlier on and change the code to suit.
I am so used to either higher or lower level languages. In assembler for example I would use
Call stringprint
This is the text
NULL CHAR
And use the program counter as the pointer.
I do appreciate everything that's been said. It's a steep learning curve switching programming languages but I'm starting to get the hang of more of this one now
Serial.print(char ) doesn't allocate any temp space at all. It just keeps calling Serial.write(byte) with incrementing the char, so one byte at a time. There is no cost (except for return address and byte on stack) to SRAM for calling Serial.print. This also explains why the Serial.print will not print strings stored in FLASH. Print assumes the char * is a pointer to SRAM location. You can probably hack the library to add an overloaded print that takes PROGMEM_P sort of pointer (Am I right on the data type?).
