I'm trying to get 2 way serial communication working over ATTiny85.
My setup:
The ATtiny85 is connected through an UNO which is tri-stated (RESET connected to GND). The connections between the UNO and ATTiny are VCC (5V), GND, TX to TX and RX to RX.
I'm using ATTinyCore, and its built-in Serial object.
I'm running the following code:
unsigned char *buffer = Serial._rx_buffer->buffer;
int *head = &Serial._rx_buffer->head;
int *tail = &Serial._rx_buffer->tail;
Serial.print(*head);
Serial.print(",\t");
Serial.print(*tail);
for (size_t index = 0; index < SERIAL_BUFFER_SIZE; index++) {
const size_t adjusted_index = (index + *tail) % SERIAL_BUFFER_SIZE;
const unsigned int value = static_cast<unsigned int>(buffer[adjusted_index]);
Serial.print(value);
Serial.print("\t");
Serial.print(Serial.available());
Serial.print(Serial.read());
Serial.print("\n");
delay(5000);
As can be seen, I'm inspecting the circular buffer used internally by the serial object. The circular buffer has the following structure:
struct soft_ring_buffer
unsigned char buffer[SERIAL_BUFFER_SIZE];
int head;
int tail;
The tail points to the next byte to be read, while the head points after the last byte written. Both wrap around when reaching SERIAL_BUFFER_SIZE (32 in my case).
I've run the code and received the following output:
14, 1, 248 248 168 173 22 87 229 206 143 184 25 215 164 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 240 , 13, 248
14, 2, 248 168 173 22 87 229 206 143 184 25 215 164 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 240 248 , 12, 248
14, 3, 168 173 22 87 229 206 143 184 25 215 164 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 240 248 248 , 11, 168
14, 4, 173 22 87 229 206 143 184 25 215 164 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 240 248 248 168 , 10, 173
14, 5, 22 87 229 206 143 184 25 215 164 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 240 248 248 168 173 , 9, 22
14, 6, 87 229 206 143 184 25 215 164 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 240 248 248 168 173 22 , 8, 87
14, 7, 229 206 143 184 25 215 164 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 240 248 248 168 173 22 87 , 7, 229
14, 8, 206 143 184 25 215 164 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 240 248 248 168 173 22 87 229 , 6, 206
14, 9, 143 184 25 215 164 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 240 248 248 168 173 22 87 229 206 , 5, 143
14, 10, 184 25 215 164 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 240 248 248 168 173 22 87 229 206 143 , 4, 184
14, 11, 25 215 164 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 240 248 248 168 173 22 87 229 206 143 184 , 3, 25
14, 12, 215 164 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 240 248 248 168 173 22 87 229 206 143 184 25 , 2, 215
14, 13, 164 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 240 248 248 168 173 22 87 229 206 143 184 25 215 , 1, 164
14, 14, 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 240 248 248 168 173 22 87 229 206 143 184 25 215 164 , 0, -1
17, 14, 152 67 225 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 240 248 248 168 173 22 87 229 206 143 184 25 215 164 , 3, 152 // Sent '0'
17, 15, 67 225 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 240 248 248 168 173 22 87 229 206 143 184 25 215 164 152 , 2, 67
17, 16, 225 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 240 248 248 168 173 22 87 229 206 143 184 25 215 164 152 67 , 1, 225
17, 17, 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 240 248 248 168 173 22 87 229 206 143 184 25 215 164 152 67 225 , 0, -1
20, 17, 152 67 225 0 0 0 0 0 0 0 0 0 0 0 0 240 248 248 168 173 22 87 229 206 143 184 25 215 164 152 67 225 , 3, 152 // Sent '0'
20, 18, 67 225 0 0 0 0 0 0 0 0 0 0 0 0 240 248 248 168 173 22 87 229 206 143 184 25 215 164 152 67 225 152 , 2, 67
20, 19, 225 0 0 0 0 0 0 0 0 0 0 0 0 240 248 248 168 173 22 87 229 206 143 184 25 215 164 152 67 225 152 67 , 1, 225
20, 20, 0 0 0 0 0 0 0 0 0 0 0 0 240 248 248 168 173 22 87 229 206 143 184 25 215 164 152 67 225 152 67 225 , 0, -1
23, 20, 152 67 225 0 0 0 0 0 0 0 0 0 240 248 248 168 173 22 87 229 206 143 184 25 215 164 152 67 225 152 67 225 , 3, 152 // Sent '0'
23, 21, 67 225 0 0 0 0 0 0 0 0 0 240 248 248 168 173 22 87 229 206 143 184 25 215 164 152 67 225 152 67 225 152 , 2, 67
23, 22, 225 0 0 0 0 0 0 0 0 0 240 248 248 168 173 22 87 229 206 143 184 25 215 164 152 67 225 152 67 225 152 67 , 1, 225
23, 23, 0 0 0 0 0 0 0 0 0 240 248 248 168 173 22 87 229 206 143 184 25 215 164 152 67 225 152 67 225 152 67 225 , 0, -1
26, 23, 153 67 225 0 0 0 0 0 0 240 248 248 168 173 22 87 229 206 143 184 25 215 164 152 67 225 152 67 225 152 67 225 , 3, 153 // Sent '1'
26, 24, 67 225 0 0 0 0 0 0 240 248 248 168 173 22 87 229 206 143 184 25 215 164 152 67 225 152 67 225 152 67 225 153 , 2, 67
26, 25, 225 0 0 0 0 0 0 240 248 248 168 173 22 87 229 206 143 184 25 215 164 152 67 225 152 67 225 152 67 225 153 67 , 1, 225
26, 26, 0 0 0 0 0 0 240 248 248 168 173 22 87 229 206 143 184 25 215 164 152 67 225 152 67 225 152 67 225 153 67 225 , 0, -1
29, 26, 176 67 225 0 0 0 240 248 248 168 173 22 87 229 206 143 184 25 215 164 152 67 225 152 67 225 152 67 225 153 67 225 , 3, 176 // sent 'a'
29, 27, 67 225 0 0 0 240 248 248 168 173 22 87 229 206 143 184 25 215 164 152 67 225 152 67 225 152 67 225 153 67 225 176 , 2, 67
29, 28, 225 0 0 0 240 248 248 168 173 22 87 229 206 143 184 25 215 164 152 67 225 152 67 225 152 67 225 153 67 225 176 67 , 1, 225
29, 29, 0 0 0 240 248 248 168 173 22 87 229 206 143 184 25 215 164 152 67 225 152 67 225 152 67 225 153 67 225 176 67 225 , 0, -1
Note the comments I added at the end of lines where I sent input.
To sum this up I see 2 strange behaviors:
The Serial is initialized with 14 bytes of data to be read which seem to be constant. Why is that? I'd expect it to have no data until someone actively writes to it. Might it be my serial monitor sending data when opening the channel?
Each time I send data I get 3 bytes which don't seem to correspond to the characters I've sent, and are not always consistent. From this example I got:
'0' -> 152, 67, 225
'1' -> 153, 67, 225
'a' -> 176, 67, 225
Let's assume I should just ignore the last 2 constant numbers. Even then, the first number is not an ascii representation, or even an offset one. How am I supposed to receive data reliably?
