I'm using an Arduino UNO and having some odd behavior with multiplying integers.
int timer_duration_ms = 2 * 60 * 1000;
Serial.println(timer_duration_ms);
Outputs "-11072"!
Any idea what I'm doing wrong?
Outputs "-11072"!
unsigned long timer_duration_ms = 2 * 60 * 1000UL;
You're trying to squeeze a quart into a pint pot.
TheMemberFormerlyKnownAsAWOL:
16.87 bits into a 16-bit variable. 15 bit, is you take sign into account.
wrybread:
I'm using an Arduino UNO and having some odd behavior with multiplying integers.int timer_duration_ms = 2 * 60 * 1000;
Serial.println(timer_duration_ms);Outputs "-11072"!
On the platform you are using, 'int' can hold values from -32768 to +32767. Your calculation overflows, and you end up with junk.
Try using 'long int' instead. It can hold values from about -2 billion to + 2 billion.
