strange issue with ethernet class
arduino 1.02
Uno R3
vfd\lcd display via I2C
i am using the ethernet class distributed with the IDE
here are code snippets, I have removed everything in the loop since it does not pertain to the specific issue
my goal is to be able to change the ip address via a keypad and display (i will store it later)
i would like to display and modify the existing IP (it is ip and assigned in code)
if i do this
IPAddress ip(192,168,10, 177);
lcd.print(ip)
it display correctly on lcd, if i change the 10 to 010, it will print the ip address as 192.168.8.177 instead of 192.168.10.177
i would really like to know if there is a way to the ipaddress that is stored in ip into another format so that i can display it as 192.168.010.177 (note leadng 0) so i can easily change via keypad
(that portion of code works but need 3 digits then decimal three digits the decimal etc. and i dont want to have to type the dots when typing it(also working)
#include <Keypad_I2C.h>
#include <EEPROM.h>
#include <avr/wdt.h>
#include <SPI.h>
#include <Ethernet.h>
#include <Keypad.h>
#include <MagStripe.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x20,6,5,4,0,1,2,3);
int SEvent = 0;         // incoming serial byte
int EGMTx = 0;
int TimeOut =20;
byte enable[5] = {0x01,0x0E,0x01,0x45,0xD1};
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,10,177);
IPAddress gateway(192,168,10, 2);
IPAddress subnet(255, 255, 255, 0);
const byte rows = 3; //four rows
const byte cols = 4; //three columns
char keys[rows][cols] = {
  {'1','2','3','C'} ,
  {'4','5','6','0'} ,
  {'7','8','9','E'}};
byte rowPins[rows] = {0,1,2}; //connect to the row pinouts of the keypad
byte colPins[cols] = {6,5,4,3}; //connect to the column pinouts of the keypad
int i2caddress = 0x21;
Keypad_I2C keypad = Keypad_I2C( makeKeymap(keys), rowPins, colPins, rows, cols, i2caddress );
template<class T>
void MyLCD(byte col, byte row, T t);
// function definition
template<class T>
  lcd.setCursor(col,row);
  lcd.print(t);
MagStripe card;
 * Track 3 is the one that can contain the most characters (107).
 * We add one more to accomodate the final '\0', as the data is a C string...
static const byte DATA_BUFFER_LEN = 108;
static char data[DATA_BUFFER_LEN];
static bool cardinsert = 0;
static bool cardallin = 0;
short myChars = 0;
byte mySrvCmd = 0;
// telnet defaults to port 23
EthernetServer server(8888);
boolean alreadyConnected = false; // whether or not the client was connected previously
long previousMillis = 0;
long interval = 1000;
long lpcount = 0;
byte sendInfo = 0;
int value;
  lcd.begin(20, 2);
  if ( value = EEPROM.read(0) == 255)
    lcd.setCursor(0, 0);
    //size_t before = getFreeMemory ();
    //lcd.print(before);
    getipaddress();
    delay(1000000);
  // initialize the ethernet device
  Ethernet.begin(mac, ip, gateway, subnet);
  // start listening for clients
  //server.begin();
  lcd.print("CMS");
  lcd.setCursor(10, 0);
  lcd.print("No Card  ");
  lcd.setCursor(5, 1);
  lcd.print("Insert Card    ");
void getipaddress()
  //char IPaddr[16]= {'0','0','0','.','0','0','0','.','0','0','0','.','0','0','0'    };
  char IPaddr[16]= {ip};
  boolean goodIP = false;
  byte IPpos = 1 ;
  lcd.setCursor(7,0);
  lcd.print("Enter IP Address");
  lcd.setCursor(1,1);
  lcd.print(ip);
  //lcd.print("000.000.000.000");
  lcd.setCursor(1,1);
  lcd.blink();
  do
    char key = keypad.getKey();
    if (key != NO_KEY){
      if (key == 'C')//backup
        if (IPpos == 5 || IPpos == 9 || IPpos == 13)//skip over decimal
          IPpos -= 2;
          lcd.setCursor(IPpos, 1);
        else if (IPpos == 1) //dont pass to left of first digit of ip
          IPpos -= 1;
      else if(key == 'E')
        //code to validate and save to eeprom
        wdt_enable (WDTO_1S);
        while (true) ;
        if (IPpos == 15)
          lcd.setCursor(4, 0);
          lcd.print(IPaddr);
        else if (IPpos == 3 || IPpos == 7 || IPpos == 11)
          lcd.setCursor(IPpos+2, 1);
          IPpos += 2;
          lcd.setCursor(IPpos+1, 1);
          IPpos += 1;
        if (IPpos == 1 || IPpos == 5 || IPpos == 9 || IPpos == 13)
          if (key > '2')
            key = '2';
          IPaddr[IPpos - 1] = key;
          lcd.print(key);
          IPpos += 1;
        else if (IPpos == 2 || IPpos == 6 || IPpos == 10 || IPpos == 14)
          if (IPaddr[IPpos - 2] == '2' && key > '5')
            key = '5';
          lcd.print(key);
          IPpos += 1;
        else if (IPpos == 3 || IPpos == 7 || IPpos == 11 || IPpos == 15)//skip over decimal
          if (IPaddr[IPpos - 3] == '2' && IPaddr[IPpos - 2] == '5' && key > '5')
            key = '5';
          else if (IPaddr[IPpos - 3] == '0' && IPaddr[IPpos - 2] == '0' && key == '0' && (IPpos == 3 || IPpos == 15))
            key = '1';
          lcd.print(key);
          if (IPpos == 15)
            lcd.setCursor(IPpos , 1);
            IPpos += 2;
          //lcd.setCursor(IPpos, 1);
          //lcd.print(key);
          //IPpos += 1;
  while (goodIP == false);
That happens because any constant that starts with a 0 is an octal constant. 010 = 8.
Sure. Store the data as a string. Parse and convert to int as required.
PaulS:
Thanks good to know about leading 0,
since i am pulling the ip address from the the ethernet library and it appears to be stored as a 4 byte array so i can do a loop through that array to get each octet. is there a command to take the numerice value 192 or any value in that case and convert to a char array so char myarray[0] would = 1, myarray[1] would = 9, myarray[2] would = 2, etc, etc or would i have to convert to a string first then parse it out and take each character to the array
in VB i have a num2BCD funtion that does this (takes any value and converts to a byte array but know clue how do to on arduno
itoa()
PaulS:
itoa()
thanks again now hopefully just one more question is there an equivalent to array.copy so that i may take the array that was created with itoa() which i will do for all 4 octets and merge or copy them into the 1 bigger array that will have all elements of the ip address,
then once ip address is changed then i will take information back to the ip address format using atoi() i assume
char octet[3] = {};
char IPaddr [16] = {};
 itoa ( ip[0], octet, 10 );
 array.copy(octet,0,IPaddr,0,3); // looking for a way to do this in arduino
itoa ( ip[1], octet, 10 );
 array.copy(octet,0,IPaddr,3,3); // looking for a way to do this in arduino
  byte IPpos = 1 ;
  lcd.setCursor(7,0);
  lcd.setCursor(1,1);
  for (byte xxx = 0; xxx < 16; xxx++)
  lcd.print(IPaddr[xxx]);
I think this needs moved to programming since not really a ethernet issue although it is an ip address
Getting Closer found memcpy
now need to figure a way to pad octet with leading 0 if the value was 99 or less
my ouput looks like this
X92.168.20X.177 where X is a block(garbage character) the first on on first char i am unsure why it is a block
the second X is becuase i need to figure a way to do a leading 0 if value is less than 99
char octet[3] = {};
char IPaddr [15] = {};
 memcpy(IPaddr  , octet, 3);
 memcpy(IPaddr + 4 ,octet, 3);
 itoa ( ip[2], octet, 10 );
 memcpy(IPaddr +8, octet,3);
 itoa ( ip[3], octet, 10 );
 memcpy(IPaddr + 12 ,octet,3);
 IPaddr[3] = '.';
 IPaddr[7] = '.';
 IPaddr[11] = '.';
  byte IPpos = 1 ;
  lcd.setCursor(7,0);
  lcd.setCursor(1,1);
  for (byte xxx = 0; xxx < 15; xxx++)
I was going to recommend strcpy(). I think you'll find that does what you want better.
The array passed to itoa() needs to be big enough to hold the integer value as a string AND the terminating NULL. "192" is 3 bytes. The terminating NULL makes 4. Your octet array is too small.
IPaddr is too small, too. 192.168.010.001 is 15 bytes. The terminating NULL makes 16.
PaulS:
I was going to recommend strcpy(). I think you’ll find that does what you want better.
The array passed to itoa() needs to be big enough to hold the integer value as a string AND the terminating NULL. “192” is 3 bytes. The terminating NULL makes 4. Your octet array is too small.
i looked at strcpy() and unless i missed it i didnt see where you could copy only certain length of the char arry i changed the size of the octet{4] and IPaddr[16] as mention i also looped it and finally have the result i want. now to put the changed ip backto to the ip address format
thanks for the help
here is the final code that you all helped with
char IPaddr [16]= "000.000.000.000";
  char octet[4] = {};
  byte pad = 0;
  for (byte AA = 0; AA < 4; AA++)
    pad = 0;
    if (ip[AA]<100){
      pad = 1;
    if (ip[AA]<10) {
      pad = 2;
    itoa ( ip[AA], octet, 10 );
    memcpy(IPaddr + (AA * 4  + pad) , octet, 3-pad);
here is the entire function final code
void getipaddress()
  char octet[4] = {};
  byte pad = 0;
    pad = 0;
    if (ip[AA]<100){
      pad = 1;
    if (ip[AA]<10) {
      pad = 2;
  byte IPpos = 1 ;
  lcd.setCursor(7,0);
  lcd.setCursor(1,1);
  lcd.setCursor(1,1);
  lcd.blink();
  do
    if (key != NO_KEY){
          IPpos -= 2;
          IPpos -= 1;
      else if(key == 'E')
        //code to validate and save to eeprom also E move char by char to end to move to a diff location
        //wdt_enable (WDTO_1S); // this is there just to play with WDT reset
        //while (true) ;        //when E is press
        if (IPpos == 15)
          lcd.print(IPaddr); // this is where  will call code to save ip address if E is pressed and on last digit of ip
          IPpos += 2;
          IPpos += 1;
          if (key > '2')
            key = '2';
          lcd.print(key);
          IPpos += 1;
            key = '5';
          lcd.print(key);
          IPpos += 1;
            key = '5';
            key = '1';
          lcd.print(key);
          if (IPpos == 15)
            IPpos += 2;
          //lcd.print(key);
          //IPpos += 1;
Why do you want to copy only part of octet? Maybe what you are looking for is strcat() to append octet onto the end of IPaddr.
