strange issue with global variable
I had a simple blink sketch. My intention was to control number of blink by a global maxLoop variable. I also defined a global loopCount in order to remember how many times it blinked. The strange thing about this sketch was that it will continue blink regardless my condition check. The even stranger part was that if I uncommented either the Serial.println() or delay() line before the if condition, the sketch then worked as expected.
Could anyone run this program and see if it behaves the same? Thanks!
Blink
Turns on an LED on for one second, then off for one second, repeatedly.
This example code is in the public domain.
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
int led = 13;
int maxLoop = 3;
int loopCount =0;
// the setup routine runs once when you press reset:
// initialize the digital pin as an output.
pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
++loopCount;
//Serial.println("Loop() has run " + String(loopCount) + " times");
//delay(1000);
if(loopCount < maxLoop){
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
} // wait for a second
I run the same sketch in an Intel Edison board. The behavior was somewhat different. The LED did stop blink but after a while (may be 1 minute) it started blinking without stopping.
To me, this looks like an overflow. So, I added another deply(1000) in the loop(). This fixed the issue for both board.
Haha, yes, because after the if condition fails, loopCount is incremented rapidly and rolls over to zero. There are no delays if the loop condition is not satisfied.
This is an abuse of the loop function. It should be empty, and the code should be moved to a while loop inside the setup function. Or, that is the way with the fewest changes.
Yes, you are right about the int overflow. Thanks.
This is the code fixed:
int led = 13;
int maxLoop = 3;
int loopCount =0;
++loopCount;
