I have just tried to program a board that has been programming fine for ages. Based on an ATTiny3217. I get the following error.
Arduino: 1.8.15 (Linux), Board: "ATtiny3227/3217/1627/1617/1607/827/817/807/427/417, ATtiny3217, 20 MHz internal, 1.8V (5 MHz or less), Disabled/Disabled, EEPROM retained, Enabled (default timer), UPDI (no reset pin), 8ms, Ignore (saves flash, almost always fine)"
/snap/arduino/61/arduino-builder -dump-prefs -logger=machine -hardware /snap/arduino/61/hardware -hardware /home/jason/snap/arduino/61/.arduino15/packages -hardware /home/jason/snap/arduino/current/Arduino/hardware -tools /snap/arduino/61/tools-builder -tools /snap/arduino/61/hardware/tools/avr -tools /home/jason/snap/arduino/61/.arduino15/packages -built-in-libraries /snap/arduino/61/libraries -libraries /home/jason/snap/arduino/current/Arduino/libraries -fqbn=megaTinyCore:megaavr:atxy7:chip=3217,clock=20internal,bodvoltage=1v8,bodmode=disabled,eesave=enable,millis=enabled,resetpin=UPDI,startuptime=8,uartvoltage=skip -vid-pid=1A86_7523 -ide-version=10815 -build-path /tmp/arduino_build_375321 -warnings=none -build-cache /tmp/arduino_cache_548911 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=/snap/arduino/61/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=/snap/arduino/61/hardware/tools/avr -verbose /home/jason/snap/arduino/current/Arduino/PI_GPI_ATRE_OLED_TNR_3217/PI_GPI_ATRE_OLED_TNR_3217.ino
/snap/arduino/61/arduino-builder -compile -logger=machine -hardware /snap/arduino/61/hardware -hardware /home/jason/snap/arduino/61/.arduino15/packages -hardware /home/jason/snap/arduino/current/Arduino/hardware -tools /snap/arduino/61/tools-builder -tools /snap/arduino/61/hardware/tools/avr -tools /home/jason/snap/arduino/61/.arduino15/packages -built-in-libraries /snap/arduino/61/libraries -libraries /home/jason/snap/arduino/current/Arduino/libraries -fqbn=megaTinyCore:megaavr:atxy7:chip=3217,clock=20internal,bodvoltage=1v8,bodmode=disabled,eesave=enable,millis=enabled,resetpin=UPDI,startuptime=8,uartvoltage=skip -vid-pid=1A86_7523 -ide-version=10815 -build-path /tmp/arduino_build_375321 -warnings=none -build-cache /tmp/arduino_cache_548911 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=/snap/arduino/61/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=/snap/arduino/61/hardware/tools/avr -verbose /home/jason/snap/arduino/current/Arduino/PI_GPI_ATRE_OLED_TNR_3217/PI_GPI_ATRE_OLED_TNR_3217.ino
Using board 'atxy7' from platform in folder: /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2
Using core 'megatinycore' from platform in folder: /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2
Detecting libraries used...
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /tmp/arduino_build_375321/sketch/PI_GPI_ATRE_OLED_TNR_3217.ino.cpp -o /dev/null
Alternatives for Adafruit_GFX.h: [Adafruit_GFX_Library@1.10.12]
ResolveLibrary(Adafruit_GFX.h)
-> candidates: [Adafruit_GFX_Library@1.10.12]
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library /tmp/arduino_build_375321/sketch/PI_GPI_ATRE_OLED_TNR_3217.ino.cpp -o /dev/null
Alternatives for Adafruit_SSD1306.h: [Adafruit_SSD1306@2.5.1]
ResolveLibrary(Adafruit_SSD1306.h)
-> candidates: [Adafruit_SSD1306@2.5.1]
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 /tmp/arduino_build_375321/sketch/PI_GPI_ATRE_OLED_TNR_3217.ino.cpp -o /dev/null
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src /tmp/arduino_build_375321/sketch/PI_GPI_ATRE_OLED_TNR_3217.ino.cpp -o /dev/null
Alternatives for Wire.h: [Wire@1.1.2]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.1.2]
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src /tmp/arduino_build_375321/sketch/PI_GPI_ATRE_OLED_TNR_3217.ino.cpp -o /dev/null
Alternatives for EEPROM.h: [EEPROM@2.0]
ResolveLibrary(EEPROM.h)
-> candidates: [EEPROM@2.0]
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src /tmp/arduino_build_375321/sketch/PI_GPI_ATRE_OLED_TNR_3217.ino.cpp -o /dev/null
Alternatives for GEARS_C059_INV.h: [GEARS_C059_INV]
ResolveLibrary(GEARS_C059_INV.h)
-> candidates: [GEARS_C059_INV]
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV /tmp/arduino_build_375321/sketch/PI_GPI_ATRE_OLED_TNR_3217.ino.cpp -o /dev/null
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV /home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library/Adafruit_GFX.cpp -o /dev/null
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV /home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library/Adafruit_GrayOLED.cpp -o /dev/null
Alternatives for Adafruit_I2CDevice.h: [Adafruit_BusIO@1.10.1]
ResolveLibrary(Adafruit_I2CDevice.h)
-> candidates: [Adafruit_BusIO@1.10.1]
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO /home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library/Adafruit_GrayOLED.cpp -o /dev/null
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO /home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library/Adafruit_SPITFT.cpp -o /dev/null
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO /home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library/glcdfont.c -o /dev/null
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO /home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306/Adafruit_SSD1306.cpp -o /dev/null
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src/SPI.cpp -o /dev/null
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src/Wire.cpp -o /dev/null
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src/utility/twi.c -o /dev/null
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO /home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO/Adafruit_BusIO_Register.cpp -o /dev/null
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO /home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO/Adafruit_I2CDevice.cpp -o /dev/null
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO /home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO/Adafruit_SPIDevice.cpp -o /dev/null
Generating function prototypes...
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO /tmp/arduino_build_375321/sketch/PI_GPI_ATRE_OLED_TNR_3217.ino.cpp -o /tmp/arduino_build_375321/preproc/ctags_target_for_gcc_minus_e.cpp
/snap/arduino/61/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino_build_375321/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO /tmp/arduino_build_375321/sketch/PI_GPI_ATRE_OLED_TNR_3217.ino.cpp -o /tmp/arduino_build_375321/sketch/PI_GPI_ATRE_OLED_TNR_3217.ino.cpp.o
Compiling libraries...
Compiling library "Adafruit_GFX_Library"
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO /home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library/glcdfont.c -o /tmp/arduino_build_375321/libraries/Adafruit_GFX_Library/glcdfont.c.o
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO /home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library/Adafruit_GFX.cpp -o /tmp/arduino_build_375321/libraries/Adafruit_GFX_Library/Adafruit_GFX.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO /home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library/Adafruit_SPITFT.cpp -o /tmp/arduino_build_375321/libraries/Adafruit_GFX_Library/Adafruit_SPITFT.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO /home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library/Adafruit_GrayOLED.cpp -o /tmp/arduino_build_375321/libraries/Adafruit_GFX_Library/Adafruit_GrayOLED.cpp.o
Compiling library "Adafruit_SSD1306"
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO /home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306/Adafruit_SSD1306.cpp -o /tmp/arduino_build_375321/libraries/Adafruit_SSD1306/Adafruit_SSD1306.cpp.o
Compiling library "SPI"
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src/SPI.cpp -o /tmp/arduino_build_375321/libraries/SPI/SPI.cpp.o
Compiling library "Wire"
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src/Wire.cpp -o /tmp/arduino_build_375321/libraries/Wire/Wire.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src/utility/twi.c -o /tmp/arduino_build_375321/libraries/Wire/utility/twi.c.o
Compiling library "EEPROM"
Compiling library "GEARS_C059_INV"
Compiling library "Adafruit_BusIO"
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO /home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO/Adafruit_BusIO_Register.cpp -o /tmp/arduino_build_375321/libraries/Adafruit_BusIO/Adafruit_BusIO_Register.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO /home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO/Adafruit_I2CDevice.cpp -o /tmp/arduino_build_375321/libraries/Adafruit_BusIO/Adafruit_I2CDevice.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306 -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire/src -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM/src -I/home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV -I/home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO /home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO/Adafruit_SPIDevice.cpp -o /tmp/arduino_build_375321/libraries/Adafruit_BusIO/Adafruit_SPIDevice.cpp.o
Compiling core...
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc -c -g -x assembler-with-cpp -flto -MMD -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/wiring_pulse.S -o /tmp/arduino_build_375321/core/wiring_pulse.S.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/WInterrupts.c -o /tmp/arduino_build_375321/core/WInterrupts.c.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/hooks.c -o /tmp/arduino_build_375321/core/hooks.c.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/wiring_shift.c -o /tmp/arduino_build_375321/core/wiring_shift.c.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/wiring_digital.c -o /tmp/arduino_build_375321/core/wiring_digital.c.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/wiring_pulse.c -o /tmp/arduino_build_375321/core/wiring_pulse.c.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/wiring.c -o /tmp/arduino_build_375321/core/wiring.c.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/wiring_analog.c -o /tmp/arduino_build_375321/core/wiring_analog.c.o
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/UART1.cpp -o /tmp/arduino_build_375321/core/UART1.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/WMath.cpp -o /tmp/arduino_build_375321/core/WMath.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/UART.cpp -o /tmp/arduino_build_375321/core/UART.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/abi.cpp -o /tmp/arduino_build_375321/core/abi.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/UART2.cpp -o /tmp/arduino_build_375321/core/UART2.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/UART0.cpp -o /tmp/arduino_build_375321/core/UART0.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/Tone.cpp -o /tmp/arduino_build_375321/core/Tone.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/UART3.cpp -o /tmp/arduino_build_375321/core/UART3.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/main.cpp -o /tmp/arduino_build_375321/core/main.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/new.cpp -o /tmp/arduino_build_375321/core/new.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/Common.cpp -o /tmp/arduino_build_375321/core/api/Common.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/IPAddress.cpp -o /tmp/arduino_build_375321/core/api/IPAddress.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/PluggableUSB.cpp -o /tmp/arduino_build_375321/core/api/PluggableUSB.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/Print.cpp -o /tmp/arduino_build_375321/core/api/Print.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/RingBuffer.cpp -o /tmp/arduino_build_375321/core/api/RingBuffer.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/Stream.cpp -o /tmp/arduino_build_375321/core/api/Stream.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=c++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny3217 -DF_CPU=20000000L -DCLOCK_SOURCE=0 -DARDUINO=10815 -DARDUINO_AVR_ATtiny3217 -DARDUINO_ARCH_MEGAAVR "-DMEGATINYCORE=\"2.4.2\"" -DMEGATINYCORE_MAJOR=2UL -DMEGATINYCORE_MINOR=4UL -DMEGATINYCORE_PATCH=2UL -DMEGATINYCORE_RELEASED=1 -DARDUINO_attinyxy7 -DMILLIS_USE_TIMERD0 -DUARTBAUDNA -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/deprecated -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore -I/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/variants/txy7 /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/cores/megatinycore/api/String.cpp -o /tmp/arduino_build_375321/core/api/String.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_375321/core/core.a /tmp/arduino_build_375321/core/wiring_pulse.S.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_375321/core/core.a /tmp/arduino_build_375321/core/WInterrupts.c.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_375321/core/core.a /tmp/arduino_build_375321/core/hooks.c.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_375321/core/core.a /tmp/arduino_build_375321/core/wiring.c.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_375321/core/core.a /tmp/arduino_build_375321/core/wiring_analog.c.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_375321/core/core.a /tmp/arduino_build_375321/core/wiring_digital.c.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_375321/core/core.a /tmp/arduino_build_375321/core/wiring_pulse.c.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_375321/core/core.a /tmp/arduino_build_375321/core/wiring_shift.c.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_375321/core/core.a /tmp/arduino_build_375321/core/Tone.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_375321/core/core.a /tmp/arduino_build_375321/core/UART.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_375321/core/core.a /tmp/arduino_build_375321/core/UART0.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_375321/core/core.a /tmp/arduino_build_375321/core/UART1.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_375321/core/core.a /tmp/arduino_build_375321/core/UART2.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_375321/core/core.a /tmp/arduino_build_375321/core/UART3.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_375321/core/core.a /tmp/arduino_build_375321/core/WMath.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_375321/core/core.a /tmp/arduino_build_375321/core/abi.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_375321/core/core.a /tmp/arduino_build_375321/core/api/Common.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_375321/core/core.a /tmp/arduino_build_375321/core/api/IPAddress.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_375321/core/core.a /tmp/arduino_build_375321/core/api/PluggableUSB.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_375321/core/core.a /tmp/arduino_build_375321/core/api/Print.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_375321/core/core.a /tmp/arduino_build_375321/core/api/RingBuffer.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_375321/core/core.a /tmp/arduino_build_375321/core/api/Stream.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_375321/core/core.a /tmp/arduino_build_375321/core/api/String.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_375321/core/core.a /tmp/arduino_build_375321/core/main.cpp.o
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_375321/core/core.a /tmp/arduino_build_375321/core/new.cpp.o
Archiving built core (caching) in: /tmp/arduino_cache_548911/core/core_2682e087de01faa74c9eb480805b748e.a
Linking everything together...
/snap/arduino/61/hardware/tools/avr/bin/avr-gcc -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -Wl,--section-start=.text=0x0 -mrelax -mmcu=attiny3217 -o /tmp/arduino_build_375321/PI_GPI_ATRE_OLED_TNR_3217.ino.elf /tmp/arduino_build_375321/sketch/PI_GPI_ATRE_OLED_TNR_3217.ino.cpp.o /tmp/arduino_build_375321/libraries/Adafruit_GFX_Library/glcdfont.c.o /tmp/arduino_build_375321/libraries/Adafruit_GFX_Library/Adafruit_GFX.cpp.o /tmp/arduino_build_375321/libraries/Adafruit_GFX_Library/Adafruit_GrayOLED.cpp.o /tmp/arduino_build_375321/libraries/Adafruit_GFX_Library/Adafruit_SPITFT.cpp.o /tmp/arduino_build_375321/libraries/Adafruit_SSD1306/Adafruit_SSD1306.cpp.o /tmp/arduino_build_375321/libraries/SPI/SPI.cpp.o /tmp/arduino_build_375321/libraries/Wire/Wire.cpp.o /tmp/arduino_build_375321/libraries/Wire/utility/twi.c.o /tmp/arduino_build_375321/libraries/Adafruit_BusIO/Adafruit_BusIO_Register.cpp.o /tmp/arduino_build_375321/libraries/Adafruit_BusIO/Adafruit_I2CDevice.cpp.o /tmp/arduino_build_375321/libraries/Adafruit_BusIO/Adafruit_SPIDevice.cpp.o /tmp/arduino_build_375321/core/core.a -L/tmp/arduino_build_375321 -lm
/snap/arduino/61/hardware/tools/avr/bin/avr-objcopy -O binary -R .eeprom /tmp/arduino_build_375321/PI_GPI_ATRE_OLED_TNR_3217.ino.elf /tmp/arduino_build_375321/PI_GPI_ATRE_OLED_TNR_3217.ino.bin
/snap/arduino/61/hardware/tools/avr/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /tmp/arduino_build_375321/PI_GPI_ATRE_OLED_TNR_3217.ino.elf /tmp/arduino_build_375321/PI_GPI_ATRE_OLED_TNR_3217.ino.eep
/snap/arduino/61/hardware/tools/avr/bin/avr-objcopy -O ihex -R .eeprom /tmp/arduino_build_375321/PI_GPI_ATRE_OLED_TNR_3217.ino.elf /tmp/arduino_build_375321/PI_GPI_ATRE_OLED_TNR_3217.ino.hex
bash -c "/snap/arduino/61/hardware/tools/avr/bin/avr-objdump --disassemble --source --line-numbers --demangle --section=.text /tmp/arduino_build_375321/PI_GPI_ATRE_OLED_TNR_3217.ino.elf > /tmp/arduino_build_375321/PI_GPI_ATRE_OLED_TNR_3217.ino.lst"
bash -c "/snap/arduino/61/hardware/tools/avr/bin/avr-nm --numeric-sort --line-numbers --demangle --print-size --format=s /tmp/arduino_build_375321/PI_GPI_ATRE_OLED_TNR_3217.ino.elf > /tmp/arduino_build_375321/PI_GPI_ATRE_OLED_TNR_3217.ino.map"
Using library Adafruit_GFX_Library at version 1.10.12 in folder: /home/jason/snap/arduino/current/Arduino/libraries/Adafruit_GFX_Library
Using library Adafruit_SSD1306 at version 2.5.1 in folder: /home/jason/snap/arduino/current/Arduino/libraries/Adafruit_SSD1306
Using library SPI at version 1.0 in folder: /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/SPI
Using library Wire at version 1.1.2 in folder: /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/Wire
Using library EEPROM at version 2.0 in folder: /home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/libraries/EEPROM
Using library GEARS_C059_INV in folder: /home/jason/snap/arduino/current/Arduino/libraries/GEARS_C059_INV (legacy)
Using library Adafruit_BusIO at version 1.10.1 in folder: /home/jason/snap/arduino/current/Arduino/libraries/Adafruit_BusIO
/snap/arduino/61/hardware/tools/avr/bin/avr-size -A /tmp/arduino_build_375321/PI_GPI_ATRE_OLED_TNR_3217.ino.elf
Sketch uses 21770 bytes (66%) of program storage space. Maximum is 32768 bytes.
Global variables use 158 bytes (7%) of dynamic memory, leaving 1890 bytes for local variables. Maximum is 2048 bytes.
___REMOVE___/bin/avrdude -C/home/jason/snap/arduino/61/.arduino15/packages/megaTinyCore/hardware/megaavr/2.4.2/avrdude.conf -v -pattiny3217 -cjtag2updi -P/dev/ttyUSB0 -Ufuse2:w:0x02:m -Ufuse6:w:0x04:m -Ufuse8:w:0x00:m -Uflash:w:/tmp/arduino_build_375321/PI_GPI_ATRE_OLED_TNR_3217.ino.hex:i
java.io.IOException: Cannot run program "___REMOVE___/bin/avrdude": error=2, No such file or directory
at java.base/java.lang.ProcessBuilder.start(ProcessBuilder.java:1128)
at java.base/java.lang.ProcessBuilder.start(ProcessBuilder.java:1071)
at java.base/java.lang.Runtime.exec(Runtime.java:592)
at java.base/java.lang.Runtime.exec(Runtime.java:451)
at processing.app.helpers.ProcessUtils.exec(ProcessUtils.java:11)
at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:129)
at cc.arduino.packages.uploaders.SerialUploader.runCommand(SerialUploader.java:383)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingProgrammer(SerialUploader.java:315)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:90)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:77)
at processing.app.SketchController.upload(SketchController.java:732)
at processing.app.SketchController.exportApplet(SketchController.java:703)
at processing.app.Editor$UploadHandler.run(Editor.java:2055)
at java.base/java.lang.Thread.run(Thread.java:829)
Caused by: java.io.IOException: error=2, No such file or directory
at java.base/java.lang.ProcessImpl.forkAndExec(Native Method)
at java.base/java.lang.ProcessImpl.<init>(ProcessImpl.java:340)
at java.base/java.lang.ProcessImpl.start(ProcessImpl.java:271)
at java.base/java.lang.ProcessBuilder.start(ProcessBuilder.java:1107)
... 13 more
An error occurred while uploading the sketch
