I'm back to ask (again) for help. I'm currently trying to send data (a string made from 0s ans 1s) wireless from an Arduino to another , with NRF24 modules. I manage to have it working well and get the result I expect. However, I need to do the same experiment without any control protocol. Yes I deliberately want to have a potentially disturbed message.
Please note that the message is built in Python, sent to the Tx via Python serial module, and that the same is done with Rx. The data I extract from the Rx is read thanks to a few Python lines (which work).
The RF24 library allows to disable CRC if we also disable auto-ack. After a few tries and lot of worries, I finally managed to get an output from the Rx with the auto-ack disabled. However, the output is quite strange, since it seems the string is no longer encoded in the same code I sent it.
The input is :
0110010010111000110101000
Which is also what my code outputs with auto-ack enabled.
Without, though, the output becomes :
\xcd\x18\x18\x98\x98\x18\x18\x98\x18\x18\x98\x18\x98\x98\x98\x18\x18\x18\x98\x98\x18\x98\x18\x98\x18\x18\xcd\x18\x18\x98\x98\x18\x18\x98\x18\x18\x98\x18\x98\x98\x98\x18\x18\x18\x98\x98\x18\x98\x18\x98\x18\x18\xcd\x18\x18\x98\x98\x18\x18\x98\x18\x18\x98\x18\x98\x98\x98\x18\x18\x18\x98\x98\x18\x98\x18\x98\x18\x18\xcd\x18\x18\x98\ ... and so on
I checked for an Ascii translation, but it doesn't seem to fit to what I expect.
What am I doing wrong ?
Here are the codes, to give you a better picture :
Tx :
#include <SPI.h>
#include <RF24.h>
#define pinCE 7 // On associe la broche "CE" du NRF24L01 à la sortie digitale D7 de l'arduino
#define pinCSN 8 // On associe la broche "CSN" du NRF24L01 à la sortie digitale D8 de l'arduino
#define tunnel "PIPE1" // On définit un "nom de tunnel" (5 caractères), pour pouvoir communiquer d'un NRF24 à l'autre
RF24 radio(pinCE, pinCSN); // Instanciation du NRF24L01
const byte adresse[6] = tunnel; // Mise au format "byte array" du nom du tunnel
// Message à transmettre à l'autre NRF24 (32 caractères maxi, avec cette librairie)
const byte numChars = 32;
char receivedChars[numChars]; // an array to store the received data
boolean newData = false;
radio.begin(); // Initialisation du module NRF24
radio.openWritingPipe(adresse); // Ouverture du tunnel en ÉCRITURE, avec le "nom" qu'on lui a donné
radio.setPALevel(RF24_PA_MIN); // Sélection d'un niveau "MINIMAL" pour communiquer (pas besoin d'une forte puissance, pour nos essais)
radio.setCRCLength(0);
radio.stopListening();// Arrêt de l'écoute du NRF24 (signifiant qu'on va émettre, et non recevoir, ici
char message[32] = "Mon message à envoyer !";
recvWithEndMarker();
if (newData) {
showNewData();
radio.write(receivedChars, strlen(receivedChars)+1);
void recvWithEndMarker() {
static byte ndx = 0;
char endMarker = '>';
char rc;
while (Serial.available() > 0 && newData == false) {
rc = Serial.read();
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
void showNewData() {
if (newData == true) {
Serial.print(receivedChars);
newData = false;
Rx :
#include <SPI.h>
#include <RF24.h>
#define tunnel "PIPE1" // On définit le "nom de tunnel" (5 caractères) à travers lequel on va recevoir les données de l'émetteur
char message[32];
const byte numChars = 16;
char add = '\0';
// Initialisation du port série (pour afficher les infos reçues, sur le "Moniteur Série" de l'IDE Arduino)
// Partie NRF24
radio.openReadingPipe(0, adresse); // Ouverture du tunnel en LECTURE, avec le "nom" qu'on lui a donné
radio.setAutoAck(false);
radio.startListening(); // Démarrage de l'écoute du NRF24 (signifiant qu'on va recevoir, et non émettre quoi que ce soit, ici)
if (radio.available()) { // On vérifie si un message est en attente de lecture
radio.read(&message, sizeof(message));// Si oui, on le charge dans la variable "message"
newData = true;
showNewData();
char endMarker = ">" ;
char rc;
rc = Serial.read();
ndx++;
ndx = numChars - 1;
else {
ndx = 0;
newData = true;
Serial.write(message);
newData = false;
Python :
import serial
import CRC
import numpy as np
import time
a = '0110010010111000110'
CRC.Codage_Canal(a)
print(CRC.Codage_Canal(a))
ArduinoUno = serial.Serial(port="COM3", baudrate=9600, bytesize=8, timeout=2, stopbits=serial.STOPBITS_ONE)
ArduinoNano = serial.Serial(port="COM4", baudrate=9600, bytesize=8, timeout=2, stopbits=serial.STOPBITS_ONE)
time.sleep(2)
file = open('message.txt', 'r')
message = file.read()
file.close()
print(message)
messagecode = CRC.Codage_Canal(message) + '>'
print(messagecode)
#Le code fonctionne jusqu'ici
bits = []
Generateur = np.array([1, 0, 1, 1])
for i in range(len(messagecode)//8 + 1) : #On découpe en chaines de 8 bits car bytesize = 8 plus haut
chaine = ''
chaine += messagecode[8*i:8*i+8]
bits.append(chaine)
print(bits)
w = 0
while w < 1 :
w += 1
for i in range(len(bits)):
ArduinoUno.write(bytes(bits[i], encoding = 'ASCII')) #On envoie à travers le moniteur chaque groupe de 8 bits #write(bytes(bits[i]))
time.sleep(1)
recu = str(ArduinoNano.readline())[2:-1] #On stocke tout ce qui est dans le buffer de la Nano
print("reçu = ", recu)
###FONCTIONNE JUSQUE LA
decode = CRC.Decodage_Canal(recu, Generateur) #possible que le bug soit ici #decode est le reste dans la div euclidienne de la chaine reçue
print(decode)
ecrire = True #booléen
compteur = 0
while compteur < len(decode) : #On vérifie que tous les coefficients du reste sont nuls
if decode[compteur] == 0 :
compteur += 1
else:
ecrire = False
break
if ecrire : #Si le message est correct, on écrit le message reçu dans un fichier
fichier = open('reception.txt', 'a')
fichier.write(str(recu)[:-len(decode)] + '\n') #On enlève les bits de CRC à la fin du code
else :
fichier2 = open('erreurs.txt', 'a') #Sinon, on l'écrit dans un fichier d'erreurs
fichier2.write(str(recu)[:-len(decode)] + '\n')
print('fin')
Thank you very much for any help
