Strange Power Supply Issue
Hello all,
I am near the end of my proto stage with a device that opens and closes my blinds based on whether it is light or dark outside and the only thing left I have to do is figure out a mount for the servo that will be doing the work and figure out the external power supply.
The bit I am working on now is the power supply. I know it isn't good to run a servo off the 5V pin on the Arduino so I want to hook it to a second power supply and just keep the signal wire going to the Arduino. When I have the servo powered by the Arduino (without any load, which I heard was ok to do) it works perfectly and my code is executed the way it is supposed to be. When I replace the + and - wires coming from the Arduino 5V with the + and - wired coming from a 4x AA battery pack (6V) the servo just rotates seemingly randomly! It is very frustrating. It is like it completely ignores the code. The servo does stop sometimes when I cover the LDR but doesnt perform any of the functions it does when connected to the Arduino 5V
I am using THIS servo
I was under the impression that the servo was only told when to go and stop by the signal wire and changing the power source wouldn't affect it. Ill paste in my code and attach my schematic below. Any pointers would be greatly appreciated! Thanks in advance
  • Sky
Code:
#include <Servo.h>
Servo myservo;                                                    //name servo
int photocellPin = 0;                                             //define photo cell reading input
int photocellReading;                                             //define photo cell reading variable
int shadeOpen = 0;
int shadeClosed = 0;
  Serial.begin(9600);                                             //initiate serial @ 9600 baud
  myservo.attach(11);                                             //define pin 11 as servo signal pin
  Serial.print("Brightness = ");                                  //print "Brightness = "
  Serial.println(photocellReading);                               //print the photocell reading
  photocellReading = analogRead(photocellPin);                    //define photocellReading as pin 0 input from LDR
  photocellReading = map(photocellReading, 0, 1023, 0, 179);      //map the LDR input to a value between 1-180 so the servo can understand it
  if (photocellReading <= 70 && shadeClosed == 0)                 //if the LDR is showing darkness and the shade isn't closed already
      myservo.write(110);                                         //then tell the servo to rotate forwards at a steady rate (close shade)
      delay(2500);                                                //2.5 second delay while shade is closing
      myservo.write(90);                                          //stop rotation after dalay
      shadeClosed = 1;                                            //set shadeClosed var as true
      shadeOpen = 0;                                              //set shadeOpen var as false
  else if (photocellReading >= 110 && shadeOpen == 0)             //if the LDR is showing light and the shade isn't open already
      myservo.write(70);                                          //then tell the servo to rotate backwards at a steady rate (open shade)
      delay(2500);                                                //2.5 second delay while shade is opening
      shadeOpen = 1;                                              //set shadeOpen var as true
      shadeClosed = 0;                                            //set shadeClosed var as false
  else if (photocellReading >= 71 && photocellReading <= 109)     //if the LDR senses neither new light or new dark (mid-day)
      myservo.write(90);                                          //stop servo
  delay(15);
Schematic:
Probably your wiring.
The attached dwg updates your schematic (same file name).
Make very sure that you still have the - signals (ground) connected between the servo and Arduino, since that would cause odd behavior. It is OK to hook up the - from the battery to the Arduino ground, just not the 5V.
My guess would be your battery GND is not connected to arduino GND.
( Replace the word "OK" in previous post with the word "MANDATORY" or "NECESSARY")
Thanks everyone you were very correct! I had no idea the Arduino ground had to be hooked up still, I thought the (-) from the battery pack would do the job but I now see that that was a stupid mistake. Thanks again! I can now proceed with testing :slight_smile:
