I am playing with hardware serial functions. Now I am stuck with a strange phenomena, relating to char array's and returning them in a method.
code:
const char CP_MARK = '
explanation to the serial dump:
available shows the queue length of the Serial Object.
the text after the ! sign is the same that i sent in the console (where i added $ marks at start + end)
output:
Sender ready
available:6
FOUND-START.....FOUND-END!asdf
aÀ
available:17
FOUND-START................FOUND-END!qwerqweqwerqwer
qwerqweqwer
available:10
FOUND-START.........FOUND-END!qwerqwer
qwer
available:6
FOUND-START.....FOUND-END!qwer
qÀ
available:3
FOUND-START..FOUND-END!q
q
why does a return of a char[] into a char* only work partially??;
const int CP_TIMEOUT = 100; //ms
char* received;
byte pos = 0;
Serial.println("Sender ready");
void loop(){
int a = Serial.available();
if(a > 0){
Serial.print("available:");
Serial.println(a);
received = receiveString(a);
Serial.println(received);
char* receiveString(byte length){
char stringIn[length+1];
char charIn;
int i = 0;
stringIn[i] = '\0';
unsigned long timeout = millis() + CP_TIMEOUT;
if(Serial.available() > 0) {
charIn = Serial.read();
if (charIn == CP_MARK){
Serial.print("FOUND-START");
while((millis() < timeout) && (i < length)) {
if(Serial.available() > 0){
Serial.print(".");
Serial.print("FOUND-END");
else {
stringIn[i++] = charIn;
stringIn[i] = '\0';
// empty buffer
while(Serial.available() > 0){
Serial.read();
Serial.print("!");
Serial.println(stringIn);
return stringIn;
output:
§DISCOURSE_HOISTED_CODE_1§
