Maybe a pair of fresh eyes can help out find out what is going on in the code.
The program just writes a byte of data to part of port b and part of port d.
Connected to those 8 pins I have a R-2R resistor ladder for conversion to analog.
The data is such that the output out of the R-2R is a sine wave.
That all works when using a for loop to read the array into the pins.
What I am trying to is timer 2 output compare interrupt to read the data.
What happens is when I run the code is the program just keeps printing the message "setting up" which is part setup() routine.
It acts like the micro is forever getting reset but the reset line stays high.
Here is the code ...
#define SAMPLE_RATE 360000
void timerSetup(void);
int i;
byte note,flag=0, myarray[360];
unsigned int counter=0;
const unsigned int sinewave[] PROGMEM ={
0x7f,0x81,0x83,0x86,0x88,0x8a,0x8c,0x8e,0x91,0x93,0x95,0x97,0x99,0x9c,0x9e,0xa0,0xa2,0xa4,0xa6,0xa8,0xaa,0xac,0xaf,0xb1,0xb3,0xb5,0xb7,0xb9,0xbb,0xbd,0xbe,0xc0,0xc2,0xc4,0xc6,0xc8,0xca,0xcb,0xcd,0xcf,0xd1,0xd2,0xd4,0xd6,0xd7,0xd9,0xda,0xdc,0xdd,0xdf,0xe0,0xe2,0xe3,0xe4,0xe6,0xe7,0xe8,0xe9,0xeb,0xec,0xed,0xee,0xef,0xf0,0xf1,0xf2,0xf3,0xf4,0xf5,0xf6,0xf6,0xf7,0xf8,0xf8,0xf9,0xfa,0xfa,0xfb,0xfb,0xfc,0xfc,0xfc,0xfd,0xfd,0xfd,0xfe,0xfe,0xfe,0xfe,0xfe,0xfe,0xfe,0xfe,0xfe,0xfe,0xfe,0xfd,0xfd,0xfd,0xfc,0xfc,0xfc,0xfb,0xfb,0xfa,0xfa,0xf9,0xf8,0xf8,0xf7,0xf6,0xf6,0xf5,0xf4,0xf3,0xf2,0xf1,0xf0,0xef,0xee,0xed,0xec,0xeb,0xea,0xe8,0xe7,0xe6,0xe5,0xe3,0xe2,0xe0,0xdf,0xdd,0xdc,0xda,0xd9,0xd7,0xd6,0xd4,0xd2,0xd1,0xcf,0xcd,0xcc,0xca,0xc8,0xc6,0xc4,0xc2,0xc1,0xbf,0xbd,0xbb,0xb9,0xb7,0xb5,0xb3,0xb1,0xaf,0xad,0xab,0xa9,0xa6,0xa4,0xa2,0xa0,0x9e,0x9c,0x9a,0x97,0x95,0x93,0x91,0x8f,0x8c,0x8a,0x88,0x86,0x84,0x81,0x7f,0x7d,0x7b,0x79,0x76,0x74,0x72,0x70,0x6e,0x6b,0x69,0x67,0x65,0x63,0x60,0x5e,0x5c,0x5a,0x58,0x56,0x54,0x52,0x50,0x4e,0x4c,0x4a,0x48,0x46,0x44,0x42,0x40,0x3e,0x3c,0x3a,0x38,0x36,0x35,0x33,0x31,0x2f,0x2e,0x2c,0x2a,0x29,0x27,0x25,0x24,0x22,0x21,0x1f,0x1e,0x1c,0x1b,0x1a,0x18,0x17,0x16,0x15,0x13,0x12,0x11,0x10,0x0f,0x0e,0x0d,0x0c,0x0b,0x0a,0x09,0x09,0x08,0x07,0x06,0x06,0x05,0x04,0x04,0x03,0x03,0x02,0x02,0x02,0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x02,0x02,0x02,0x03,0x03,0x04,0x04,0x05,0x05,0x06,0x07,0x08,0x08,0x09,0x0a,0x0b,0x0c,0x0d,0x0e,0x0f,0x10,0x11,0x12,0x13,0x14,0x16,0x17,0x18,0x19,0x1b,0x1c,0x1d,0x1f,0x20,0x22,0x23,0x25,0x27,0x28,0x2a,0x2b,0x2d,0x2f,0x31,0x32,0x34,0x36,0x38,0x3a,0x3b,0x3d,0x3f,0x41,0x43,0x45,0x47,0x49,0x4b,0x4d,0x4f,0x51,0x53,0x55,0x57,0x59,0x5c,0x5e,0x60,0x62,0x64,0x66,0x69,0x6b,0x6d,0x6f,0x71,0x74,0x76,0x78,0x7a,0x7c
//for sine wave we want to set up so this is call at 360 khz
ISR(TIMER2_COMPA_vect) {
//note = myFile.read();
note= pgm_read_byte (&(sinewave[counter])) ;
PORTB = (note >> 6) & 0x03 ;
PORTD = (note << 2) & 0xfc;
myarray[counter]=note;
counter++;
//flag=1;
void timerSetup() {
ASSR &= ~(_BV(EXCLK) | _BV(AS2)); //use internal clock
TCCR2A |= _BV(WGM21); // clear timer on compare
TCCR2A &= ~( _BV(WGM20) | _BV(COM2A0) | _BV(COM2A1) ); //OCRA pin disconnected
TCCR2B |= (_BV(CS20) | _BV(CS21)); //div by x prescaler
TCCR2B &= ~( _BV(CS22) | _BV(CS22) | _BV(WGM22)); //reset these bits
//TCCR2B &= ~(_BV(CS22) | _BV(CS21) | _BV(WGM22));
OCR2A = F_CPU/SAMPLE_RATE;
//OCR2A = 250;
TIMSK2 |= _BV(OCIE2A); //enable compare A match interrupt and
TIMSK2 &= ~(_BV(OCIE2B) | _BV(TOIE2)); //disable these
interrupts(); //turn on interrupts
while (!Serial); // wait for serial port to connect. Needed for native USB port only
Serial.println("Setting up");
noInterrupts();
timerSetup();
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
pinMode(2,OUTPUT);
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(7,OUTPUT);
interrupts();
} //setup
/*confirm register values
Serial.println("In the loop ");
Serial.println("TCCR2A IS "); Serial.println(TCCR2A,HEX);
Serial.println("TCCR2B IS ");Serial.println(TCCR2B,HEX);
Serial.println("OCR2A IS "); Serial.println(OCR2A ,HEX);
Serial.println("TIMSK2 IS "); Serial.println( TIMSK2 ,HEX);
if(counter > 359) {
noInterrupts(); //turn off interrupts
for (i=0;i<360;i++)
Serial.println(myarray[i],HEX);
while(1);
} //if
} //loop
