Strange problem with the Tools menu
Hi all,
I have a rather strange problem in th Arduino IDE. Every time I try to open the Tools menu, it takes between 5 and 8 seconds to open. Im working with the Arduino BT and I think it might be the process of listing the available serial ports. Any ideas on how to avoid this delay?
Thanks in advance,
LEo
The delay is almost certainly the enumeration of the available serial ports. What operating system are you on? Does this happen if you unpair or otherwise remove the serial port corresponding to the Arduino BT? What other serial ports do you have?
