Hi
I've just took out my arduino boards again, and I tought I should start with just the easy Knob tutorial to refresh my arduino skills
Anyhow, I've noticed the servo didn't respond like it should. So I put
a serial.print on the reading just to see the value. And it's stuck around 250-300, no matter how I adjust the pot.
So first I changed to another 10k potmeter, same there. Then tried another arduino board. Same there. Also tried changing to another analog pin, but same thing there...
Then I tried the good old Arduino Diecemila(or how its written). Then it read the values perfectly!
Why wont my Picos, Nanos, Boarduino, BareBonesBoard show the correct value from 0-1023 when adjusting the pot? And only the old
diecemila. It's very strange, and I'm very confused right now ....
Cause I wanted the Modified Pico or some other board like the Boarduino to control some servos.
Only the good old arduino diecemila. Thats strange.
I use 5+ and GND for the outer pins, then the center pin I got on analog2.
Picture of the simple wiering on a Modified Pico
Uploaded with ImageShack.us
White is center pin, red & black are gnd and 5v
