This is driving me crazy! Been working for hours trying to get results. I made the example sketch below to show my problem. There are 2 places to do a Serial printing to show the value of entryName. I comment one out and run the other. If I run the one in the loop function, I get garbled values for the names. (see photo). If I run the serial print in the nextFile() routine, it prints out the names properly. I don’t understand the * char and how it is keeping my characters in the variable entryName at all. Please help!
#include <SPI.h>
#include <SD.h>
File dir;
char* entryName;
Serial.begin(9600); // Open serial communications and wait for port to open:
Serial.print("Initializing SD card...");
if (!SD.begin(10)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
dir = SD.open("/");
nextFile(); //move the next file into the variable entryName
//debug printing
// int len = strlen(entryName); //how long is the name?
// Serial.print(F("filename is: "));
// for (int i = 0; i < len; i++) {
// Serial.print(entryName[i]);
// Serial.println();
void nextFile() { //opens the next file on the SD card
File entry = dir.openNextFile();
if (! entry) { //there isn't a next file
entry.close(); //close the entry
dir.rewindDirectory(); //rewind
entry = dir.openNextFile(); //get the first file
entryName = entry.name();
entry.close();
//debug printing
SouthernAtHeart:
#include <SPI.h>
#include <SD.h>
File dir;
char* entryName;
Serial.print(“Initializing SD card…”);
Serial.println(“initialization failed!”);
return;
Serial.println(“initialization done.”);
dir = SD.open("/");
//debug printing
if (! entry) { //there isn’t a next file
entry.close();
//debug printing
You defined entryName as a pointer to a single character. So, the compiler treats it as a single character.
You assign entryName = file.name(); which loads entryName with the memory location where the filename is stored.
I think what you actually want is:
char entryName[100]; // 100 bytes to store the current filename.
if(strlen(entry.filename)<100){ //got to leave room for the terminating null
strcpy(entryName,entry.filename());
else {
sprintf(entryName,"Filename is too long, >99 bytes");
Serial.print(entryName);
The reason I copied it into a buffer, is that your code accesses the value after you have called entry.close(). There is not guarantee the the memory address entryName points to is still valid.
Wrong. entryName is defined as a variable of type pointer to char. There is no type "pointer to char array".
A variable of type pointer to char points to one char - the first one in the array. The pointer can be incremented to point to each subsequent character.
The problem with the original code is that the pointer continues to point to memory that has gone out of scope when the function ends. Using it after that happens will NOT produce valid results.
If the idea is to have the name of next file available for use after nextFile() ends, then you are correct that OP needs to make a copy of the data.
