This is my first post on here, so hello....I'm Craig!
I've been playing with various arduinos for years and know my way around electronics. I have built a project that measures three phase voltages (safely....transformers, resistors, fuses etc) and it records to an SD card with date/time stamp from DS1307. The unit is normally powered by a separate psu, but I was getting a strange reset of the date and time to default 2000,01,01,00:00:00 etc...
My first thoughts were backup battery...checked and all fine!
I then plugged the arduino into my laptop and turned just the arduino board on via its separate PSU and set the time, turned power off...waited a minute and turned back on, it worked!
Through various testing, as soon as I turn the three phase voltage on, the RTC resets back to default. Now the incoming voltage is dropped down to 3.5v MAX via transformers, diode rectification, capacitors, resistor/variable resistor decider and fuses. There are no differences in voltages between the three smaller voltages (I.e they aren't a on a different wave cycle because they are fully rectified DC signals) but I cannot work out why when I only turn the voltages on, it would reset the RTC which is something completely separate??
Just a random thought, are RTC's susceptible to interference from EMF??
Any thoughts would be greatly appreciated!!!
Craig
