Strange SD results
I am playing an SD break out that uses the standard SD library, but im having a few issues.
Trying to use the basic example i could not get the card to "initialise".
I then tried the included card info example and that did initialise but "cant find a volume".
So i compared code and found the difference was instead of using SD.begin(). It uses card.init(SPI_HALF_SPEED,6), why is this and more so, why does this one work and the other one not?
Anyway, the card now initialises but no matter what i do i cannot get any further,i have tried to different cards, all Fat combinations and i just cannot get it to open or see a file, even both cards can been seen?
What might i be doing wrong?
Thanks
Andy
What are you using to level shift the signal? (SD cards run at 3.3v). Also, are you running the connections through a solderless breadboard?
It sounds very much like you are running the system faster than your connections can handle (too much noise, stray capacitance etc.).
