I have written a little visualBasic application that sends angle-values via UDP to an arduino that writes these angles to a servo.
The value is transfered with no problems and all, but the servo likes to screw up a lot.
The value can only increase/decrease in 2°-steps which is controlled by two buttons, this way the servo should always have enough time between upd-packets to get to its new position.
The lastest value it was set to should be 44° because the application always slowy goes back in 2°-steps until it reaches 44° if there is no more input.
The Problem:
Whenever i'm not constantly updating the servo-value it runs into it's clockwise limit, which can't be good for the gears/engine inside...
shouldn't the servo stay at its last know value until it gets a new one ?
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <Servo.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 0, 178 };
byte gateway[] = { 192, 168, 0, 1 };
byte subnet[] = { 255, 255, 255, 0 };
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet
char ReplyBuffer[] = "acknowledged"; // a string to send back
byte remoteIp[4]; // holds recvieved packet's originating IP
unsigned int remotePort; // holds received packet's originating port
//Pin 11,12 & 13 are used by the EthernetShield
const int lightBackPin = 8; //Need to replace these somtime
const int lightFrontPin =9; //
const int lightPin = 8;
const int irPin =9;
const int lenk = 10;
const int cam =3;
Servo lenkServo; // Steering-Servo
Servo camServo; //Use this later for moveable camera...
int posCam=44;
int posLenk=44;
int M1 = 4;
int E1 = 5;
int E2 = 6;
int M2 = 7;
EthernetUDP Udp;
Ethernet.begin(mac, ip , gateway, subnet);
Udp.begin(9100);
pinMode(lightBackPin, OUTPUT);
pinMode(lightFrontPin, OUTPUT);
pinMode(M1,OUTPUT);
pinMode(M2,OUTPUT);
lenkServo.attach(lenk); // attaches the servo on pin 10 to the servo object
camServo.attach(cam);
lenkServo.write(44);delay(500);
int packetSize = Udp.parsePacket(); // holds received packet size
int DriveSpeed = 0;
if(packetSize)
Udp.read(packetBuffer,UDP_TX_PACKET_MAX_SIZE);
//Serial.println(packetBuffer);
switch(packetBuffer[5]){
case '-': digitalWrite(lightPin,LOW);digitalWrite(irPin,LOW);break;
case 'i': digitalWrite(lightPin,LOW);digitalWrite(irPin,HIGH);break;
case 'l': digitalWrite(lightPin,HIGH);digitalWrite(irPin,LOW);break;
case 'b': digitalWrite(lightPin,HIGH);digitalWrite(irPin,HIGH);break;
//IR = Pin 12
//Light = Pin 13
if(packetBuffer[4]!='-')
switch(packetBuffer[4]){
case '0': DriveSpeed=30;break;
case '1': DriveSpeed=55;break;
case '2': DriveSpeed=80;break;
case '3': DriveSpeed=105;break;
case '4': DriveSpeed=130;break;
case '5': DriveSpeed=155;break;
case '6': DriveSpeed=180;break;
case '7': DriveSpeed=205;break;
case '8': DriveSpeed=230;break;
case '9': DriveSpeed=255;break;
if(packetBuffer[0]=='-' & packetBuffer[1]=='-') //Stillsttand
{analogWrite(E1,0);}
if(packetBuffer[0]=='x')
{digitalWrite(M1,HIGH);analogWrite(E1,DriveSpeed);} //Rückwärts ? //
if(packetBuffer[1]=='x') //
{digitalWrite(M1,LOW);analogWrite(E1,DriveSpeed);} //Vorwärts ? //
/*old code
if(packetBuffer[2]=='-' & packetBuffer[3]=='-')//==========================Straight
if(packetBuffer[2]=='x')//=================================================Left
if(packetBuffer[3]=='x')//=================================================Right
*/ // complicated version of 'atoi()', but this works too ;P
int lenkA,lenkB;
switch(packetBuffer[6]){
case '0': lenkA=0;break;
case '1': lenkA=1;break;
case '2': lenkA=2;break;
case '3': lenkA=3;break;
case '4': lenkA=4;break;
case '5': lenkA=5;break;
case '6': lenkA=6;break;
case '7': lenkA=7;break;
case '8': lenkA=8;break;
case '9': lenkA=9;break;
case '0': lenkB=0;break;
case '1': lenkB=1;break;
case '2': lenkB=2;break;
case '3': lenkB=3;break;
case '4': lenkB=4;break;
case '5': lenkB=5;break;
case '6': lenkB=6;break;
case '7': lenkB=7;break;
case '8': lenkB=8;break;
case '9': lenkB=9;break;
posLenk=((lenkA*10)+lenkB);
Serial.println("PosLenk: ");
Serial.print(posLenk);
if(posLenk<90 & posLenk>0)
lenkServo.write(posLenk);
//delay(5);
