Previously i have tested my Arduino with a TowerPro Micro 9g servo. it is a general servo, worked fine.
Now i had to use it in a project, (RC car steering ) but it behaves very strange. When i connect to the Arduino without setting the servo up, it does nothing.
But when i connect to a pin, which is set up to a Servo library, it suddenly starts to screw to one end position, which wants to step over, and ignores the commands coming from the Arduino.
What can cause this? I haven't touched the servo for months, after the first test.
Other question, which servo library is suitable for this servo? May i trying wrong one?
OK, so that's not the root of the problem. Can be the servo faulty (but why)?
I have tried the supplied Servo Examples, Knob and Sweep, but exactly the same behavior from the servo...
OK! I will review the ground wire&connector.
Schematic : imagine as there is a PSU which powers the servo, a servo got the signal from the Arduino, and the PSU and the Arduino is grounded together
I haven't. I haven't ordered more until i don't see that i need them - now i had to order a spare/replacement one, and as if i will use more servos, i will keep some spares
Worst case is that i'll wait until the next servo arrives, and try to test again
Thanks all all helping
I have taken out the servo yesterday as i realized that it screws only to one direction as soon as it gets control signal... I tested the power connection with direct power and ground from the psu to the servo, but exactly the same issue.
May be the servo is bad, but i cannot find out why :S
(I have taken apart th servo - not difficult, 4 screws - i cannot find any failures.)
I have tried the MegaServo library, but no success :S
