First off, I apologize for the length of the code I'm posting, but the issue is difficult, (As in I'm not able to), to reproduce if anything is cut out. My situation is this: If you look towards the end of the code sample there is a function 'nodeOn_P()' which is commented out. If you run the code with this function commented out, you get the expected output, (an output of the dataArray[] in binary), but if you uncomment it you get a completely different output even though that function is not called anywhere else in the program! Does anyone know what is going on with this?
Again, sorry about the code length, I'm just trying to put some arrays in flash so that I can free up more ram.
Anyway, the code:
#include <avr/pgmspace.h>
const int mappingArray[86][2] = {
{7, 2}, // Node 0
{2, 8}, // Node 1
{5, 2}, // Node 2
{2, 10}, // Node 3
{5, 3}, // Node 4
{1, 3}, // Node 5
{4, 4}, // Node 6
{2, 3}, // Node 7
{3, 7}, // Node 8
{4, 8}, // Node 9
{0, 9}, // Node 10
{6, 2}, // Node 11
{5, 10}, // Node 12
{3, 8}, // Node 13
{4, 1}, // Node 14
{3, 3}, // Node 15
{5, 1}, // Node 16
{1, 7}, // Node 17
{1, 4}, // Node 18
{2, 4}, // Node 19
{3, 6}, // Node 20
{5, 7}, // Node 21
{2, 6}, // Node 22
{5, 9}, // Node 23
{4, 5}, // Node 24
{5, 5}, // Node 25
{7, 10}, // Node 26
{1, 10}, // Node 27
{7, 8}, // Node 28
{7, 3}, // Node 29
{3, 1}, // Node 30
{7, 9}, // Node 31
{0, 0}, // Node 32
{6, 1}, // Node 33
{6, 4}, // Node 34
{0, 3}, // Node 35
{6, 7}, // Node 36
{2, 7}, // Node 37
{5, 6}, // Node 38
{2, 1}, // Node 39
{4, 3}, // Node 40
{6, 9}, // Node 41
{3, 9}, // Node 42
{5, 8}, // Node 43
{1, 8}, // Node 44
{4, 9}, // Node 45
{4, 2}, // Node 46
{6, 10}, // Node 47
{1, 0}, // Node 48
{3, 0}, // Node 49
{7, 5}, // Node 50
{4, 7}, // Node 51
{1, 6}, // Node 52
{7, 6}, // Node 53
{4, 6}, // Node 54
{2, 2}, // Node 55
{6, 3}, // Node 56
{3, 4}, // Node 57
{7, 0}, // Node 58
{4, 0}, // Node 59
{3, 10}, // Node 60
{0, 8}, // Node 61
{0, 10}, // Node 62
{0, 1}, // Node 63
{4, 10}, // Node 64
{0, 7}, // Node 65
{7, 4}, // Node 66
{3, 5}, // Node 67
{1, 9}, // Node 68
{7, 7}, // Node 69
{6, 6}, // Node 70
{2, 5}, // Node 71
{1, 5}, // Node 72
{3, 2}, // Node 73
{6, 8}, // Node 74
{2, 0}, // Node 75
{1, 1}, // Node 76
{6, 0}, // Node 77
{5, 0}, // Node 78
{2, 9}, // Node 79
{0, 4}, // Node 80
{5, 4}, // Node 81
{6, 5}, // Node 82
{0, 6}, // Node 83
{7, 1}, // Node 84
{0, 5} // Node 85
const prog_int8_t mappingArray_P[86][2] PROGMEM = {
{7, 2}, // Node 0
{2, 8}, // Node 1
{5, 2}, // Node 2
{2, 10}, // Node 3
{5, 3}, // Node 4
{1, 3}, // Node 5
{4, 4}, // Node 6
{2, 3}, // Node 7
{3, 7}, // Node 8
{4, 8}, // Node 9
{0, 9}, // Node 10
{6, 2}, // Node 11
{5, 10}, // Node 12
{3, 8}, // Node 13
{4, 1}, // Node 14
{3, 3}, // Node 15
{5, 1}, // Node 16
{1, 7}, // Node 17
{1, 4}, // Node 18
{2, 4}, // Node 19
{3, 6}, // Node 20
{5, 7}, // Node 21
{2, 6}, // Node 22
{5, 9}, // Node 23
{4, 5}, // Node 24
{5, 5}, // Node 25
{7, 10}, // Node 26
{1, 10}, // Node 27
{7, 8}, // Node 28
{7, 3}, // Node 29
{3, 1}, // Node 30
{7, 9}, // Node 31
{0, 0}, // Node 32
{6, 1}, // Node 33
{6, 4}, // Node 34
{0, 3}, // Node 35
{6, 7}, // Node 36
{2, 7}, // Node 37
{5, 6}, // Node 38
{2, 1}, // Node 39
{4, 3}, // Node 40
{6, 9}, // Node 41
{3, 9}, // Node 42
{5, 8}, // Node 43
{1, 8}, // Node 44
{4, 9}, // Node 45
{4, 2}, // Node 46
{6, 10}, // Node 47
{1, 0}, // Node 48
{3, 0}, // Node 49
{7, 5}, // Node 50
{4, 7}, // Node 51
{1, 6}, // Node 52
{7, 6}, // Node 53
{4, 6}, // Node 54
{2, 2}, // Node 55
{6, 3}, // Node 56
{3, 4}, // Node 57
{7, 0}, // Node 58
{4, 0}, // Node 59
{3, 10}, // Node 60
{0, 8}, // Node 61
{0, 10}, // Node 62
{0, 1}, // Node 63
{4, 10}, // Node 64
{0, 7}, // Node 65
{7, 4}, // Node 66
{3, 5}, // Node 67
{1, 9}, // Node 68
{7, 7}, // Node 69
{6, 6}, // Node 70
{2, 5}, // Node 71
{1, 5}, // Node 72
{3, 2}, // Node 73
{6, 8}, // Node 74
{2, 0}, // Node 75
{1, 1}, // Node 76
{6, 0}, // Node 77
{5, 0}, // Node 78
{2, 9}, // Node 79
{0, 4}, // Node 80
{5, 4}, // Node 81
{6, 5}, // Node 82
{0, 6}, // Node 83
{7, 1}, // Node 84
{0, 5} // Node 85
// All the node numbers, so the last number of each array is negative to mark the end of the array
const prog_int8_t aRing0[] PROGMEM = {0, -1};
const prog_int8_t aRing1[] PROGMEM = {1 , 2 , 3 , 4 , 5, -1};
const prog_int8_t aRing2[] PROGMEM = {6 , 7 , 8 , 9 , 10, 11, 12, 13, 14, 15, -1};
const prog_int8_t aRing3[] PROGMEM = {16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, -1};
const prog_int8_t aRing4[] PROGMEM = {31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, -1};
const prog_int8_t aRing5[] PROGMEM = {46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, -1};
const prog_int8_t aRing6[] PROGMEM = {61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, -1};
const prog_int8_t aRing7[] PROGMEM = {76, 77, 78, 79, 80, 81, 82, 83, 84, 85, -1};
const prog_int8_t aRing8[] PROGMEM = {-1}; // Dummy for when more nodes are added
const prog_int8_t aRing9[] PROGMEM = {-1}; // Dummy for when more nodes are added
const prog_int8_t* aRingPtr[] PROGMEM = {aRing0, aRing1, aRing2, aRing3, aRing4, aRing5, aRing6, aRing7, aRing8, aRing9};
volatile byte dataArray[11]; // Essentially the main frame buffer
for(int i = 0; i <= 9; i++){
groupOn_P((prog_int8_t*)pgm_read_byte(&aRingPtr[i]));
delay(1);
printArray();
clearArray();
void printArray(){
for(int i = 0; i < 11; i++){
Serial.print(dataArray[i], BIN);
Serial.print(", ");
void clearArray(){
dataArray[i] = 0;
void groupOn_P(prog_int8_t group[]){
int index = 0;
prog_int8_t currentElement = pgm_read_byte(&group[index]);
while(currentElement >= 0){
nodeOn(currentElement);
index++;
/* Why is it that commenting this out produces different output IF I NEVER CALL IT IN THE MAIN LOOP!?
void nodeOn_P(prog_int8_t nodeNum){
prog_int8_t registerVal = pgm_read_byte(&mappingArray_P[nodeNum][1]);
prog_int8_t value = pgm_read_byte(&mappingArray_P[nodeNum][0]);
bitWrite(dataArray[registerVal], value, HIGH);
void nodeOn(int nodeNum){
bitWrite(dataArray[mappingArray[nodeNum][1]], mappingArray[nodeNum][0], HIGH);
