Strange upload behavior R4 Minima, IDE 2.34, Win 10/64
My code works, but only on the second time I click on upload. Why do I have to click upload twice?
//  OLED LMT
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_GFX.h>
#include <RTC.h>
#define OLED_WIDTH 128
#define OLED_HEIGHT 32
#define OLED_ADDR   0x3C
Adafruit_SSD1306 display(OLED_WIDTH, OLED_HEIGHT);
int counter = 0;
void setup() // splash screen
  RTC.begin();
  RTCTime startTime(03, Month::MARCH, 2025, 23, 24, 00,    DayOfWeek::SATURDAY, SaveLight::SAVING_TIME_ACTIVE);
  RTC.setTime(startTime);
  //int counter = 1;
  display.begin(SSD1306_SWITCHCAPVCC, OLED_ADDR);
  //display.setCursor(57, 13);
  //display.println(counter);
  //display.setCursor(5, 20);
  //display.println("HEINZIGHT");
  //display.setCursor(25, 45);
  //display.println("Artworks");
//int counter = 1;
RTCTime currentTime;
RTC.getTime(currentTime);
  counter ++;
  display.clearDisplay();
  display.setTextSize(2);
  display.setTextColor(WHITE);
  display.setCursor(0, 12);
  display.print("LMT");
  display.display();
  display.setTextSize(1);
  display.setCursor(40, 13);
  //for (counter = 1; counter < 61; counter++);
  if (counter > 60) counter = 1;
  //if (currentTime.getHour() < 10){
     //currentTime.getHour() = "0" + currentTime.getHour();
     display.print(currentTime.getHour());
     display.print(":");
  //if (currentTime.getMinutes() < 10){
     //currentTime.getMinutes() = "0" + currentTime.getMinutes();
     display.print(currentTime.getMinutes());
     display.print(":");
  //if (currentTime.getSeconds() < 10){
     //currentTime.getSeconds() = "0" + currentTime.getSeconds();
     display.print(currentTime.getSeconds());
  display.setCursor(40, 25);
  display.print(currentTime.getDayOfMonth());
  display.print("/");
  display.print(currentTime.getMonth());
  display.print("/");
  display.print(currentTime.getYear());
 display.display();
    delay (1000);
The Hours, Min, Sec print OK, but the time will not. R4 RTC. I was trying to use double digits for numbers less than 10 but I'll settle for single digits.
What is the time that you're referring to? I only see the printing of hours, minutes and seconds. Are you saying that it only prints those numbers after a second upload?
Note that something like below will not compile.
    display.print(":");
Thanks sterretje. Well, I mistakenly said 'time' and not 'date' will not display. But yes, the first upload does nothing. I click upload again and it runs fine. Every-time, it takes 2 clicks.
I know that date portion of the code will not compile, but why? It would help if you posted a solution, as I'm new to this stuff. That's why it's commented out.
Here's the error msg if I remove the commented out block:
C:\Users\16508\Documents\Arduino\OLED_LST_128x32\OLED_LST_128x32.ino: In function 'void loop()':
C:\Users\16508\Documents\Arduino\OLED_LST_128x32\OLED_LST_128x32.ino:77:39: error: no matching function for call to 'Adafruit_SSD1306::print(Month)'
In file included from C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/ArduinoAPI.h:31:0,
                 from C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/Arduino.h:4,
                 from C:\Users\16508\AppData\Local\arduino\sketches\2EF8EEC2E3EAD90D4E0F6D3AF7E4EB9C\sketch\OLED_LST_128x32.ino.cpp:1:
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:64:12: note: candidate: size_t arduino::Print::print(const arduino::__FlashStringHelper*)
     size_t print(const __FlashStringHelper *);
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:64:12: note:   no known conversion for argument 1 from 'Month' to 'const arduino::__FlashStringHelper*'
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:65:12: note: candidate: size_t arduino::Print::print(const arduino::String&)
     size_t print(const String &);
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:65:12: note:   no known conversion for argument 1 from 'Month' to 'const arduino::String&'
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:66:12: note: candidate: size_t arduino::Print::print(const char*)
     size_t print(const char[]);
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:66:12: note:   no known conversion for argument 1 from 'Month' to 'const char*'
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:67:12: note: candidate: size_t arduino::Print::print(char)
     size_t print(char);
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:67:12: note:   no known conversion for argument 1 from 'Month' to 'char'
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:68:12: note: candidate: size_t arduino::Print::print(unsigned char, int)
     size_t print(unsigned char, int = DEC);
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:68:12: note:   no known conversion for argument 1 from 'Month' to 'unsigned char'
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:69:12: note: candidate: size_t arduino::Print::print(int, int)
     size_t print(int, int = DEC);
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:69:12: note:   no known conversion for argument 1 from 'Month' to 'int'
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:70:12: note: candidate: size_t arduino::Print::print(unsigned int, int)
     size_t print(unsigned int, int = DEC);
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:70:12: note:   no known conversion for argument 1 from 'Month' to 'unsigned int'
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:71:12: note: candidate: size_t arduino::Print::print(long int, int)
     size_t print(long, int = DEC);
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:71:12: note:   no known conversion for argument 1 from 'Month' to 'long int'
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:72:12: note: candidate: size_t arduino::Print::print(long unsigned int, int)
     size_t print(unsigned long, int = DEC);
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:72:12: note:   no known conversion for argument 1 from 'Month' to 'long unsigned int'
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:73:12: note: candidate: size_t arduino::Print::print(long long int, int)
     size_t print(long long, int = DEC);
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:73:12: note:   no known conversion for argument 1 from 'Month' to 'long long int'
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:74:12: note: candidate: size_t arduino::Print::print(long long unsigned int, int)
     size_t print(unsigned long long, int = DEC);
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:74:12: note:   no known conversion for argument 1 from 'Month' to 'long long unsigned int'
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:75:12: note: candidate: size_t arduino::Print::print(double, int)
     size_t print(double, int = 2);
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:75:12: note:   no known conversion for argument 1 from 'Month' to 'double'
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:76:12: note: candidate: size_t arduino::Print::print(const arduino::Printable&)
     size_t print(const Printable&);
C:\Users\16508\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.2\cores\arduino/api/Print.h:76:12: note:   no known conversion for argument 1 from 'Month' to 'const arduino::Printable&'
exit status 1
Compilation error: no matching function for call to 'Adafruit_SSD1306::print(Month)'
getMonth() does not return an integer but an enum class member. the print() functions can't handle that.
Month RTCTime::getMonth() const         { return month; }
Month is one of the following:
enum class Month : uint8_t {
    JANUARY = 0,
    FEBRUARY,
    MARCH,
    APRIL,
    MAY,
    JUNE,
    JULY,
    AUGUST,
    SEPTEMBER,
    OCTOBER,
    NOVEMBER,
    DECEMBER
The above information can be found in C:\Users\yourUsername\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.4.1\libraries\RTC
You can change the problematic line to display.print((int)currentTime.getMonth()); which casts the enum to an integer.
To print leading zeroes the following
    display.print(":");
getHour() etc is a function and you can not assign a value to a function. Further combining text ("0") and numbers does not work.
The simplest way to solve leading zeroes
    display.print("0");
  display.print(":");
If you want a leading zero for the month, see the earlier comment about the casting.
I don't have an Uno R4 Minima so I can not test the behaviour. What happens when you close the serial monitor, upload a sketch and next open the serial monitor? Is the behaviour the same?
