Strange upload prolem.
Just got a strange error while uploading a sketch.
I did some modifications to my code and wanted to upload it. Then I get the following errors:
Sketch uses 28710 bytes (89%) of program storage space. Maximum is 32256 bytes.
Global variables use 1280 bytes (62%) of dynamic memory, leaving 768 bytes for local variables. Maximum is 2048 bytes.
C:\Users\dahls\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\dahls\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM19 -b115200 -D -Uflash:w:C:\Users\dahls\AppData\Local\Temp\arduino_build_612989/gy_30_sensor.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\dahls\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM19
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\dahls\AppData\Local\Temp\arduino_build_612989/gy_30_sensor.ino.hex"
avrdude: writing flash (28710 bytes):
Writing | #################################################
avrdude: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0x00
# | 100% 4.69s
avrdude: stk500_cmd(): programmer is out of sync
... [lots of this rows and it continue to write new lines until I disconnect the USB ]
avrdude: ser_send(): write error: sorry no info avail
Then I tried to upload the I2C_scanner. It worked fine.
My only question is: What is happening? Bad flash memory?
Reverted the last changes (to Serial.println() lines) and uploaded it. It worked.
The size of the sketch that work is 28574 bytes, while the bad one is 28710.
BTW, this is a UNO 3.
