I'm developing some software for an unmannned autonomous vehicle, and I've run into a very strange problem -- I have a float variable called "heading", and for testing purposes, I ended up with code like this:
Serial.println("---------TESTING");
if (heading == heading) {
Serial.println("Success");
Serial.println("TESTING---------");
The strange thing is, even though the first and last lines do print, the "Success" line doesn't! I initially wrote this code because the "heading" variable wasn't storing the proper value, and sort of out of desperation I just figured I would make sure that the variable itself was ok. Not sure where my logic was on that one, but it was late : P
Anyway, what would be a reason that a variable would not register as equal to itself?
In general you can run into problems when you try to test for equality using floats, although it is strange that a float would not register the same as itself. Try changing the code to see if it's close to itself:
I've used 0.0001 in my example, but you should choose something that's three or four orders of magnitude smaller than whatever is currently in "heading".
