#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <Wire.h>
//#include <Adafruit_BMP085.h> //Download link: https://github.com/adafruit/Adafruit-BMP085-Library
//#include "DHT.h" //Download link: https://github.com/adafruit/DHT-sensor-library
//#define DHTPIN 4
String apiKey = "FU1MDF9TXYIPU5XI";
const char* ssid = "I_AM_SLOW";
const char* password = "9601121798";
const char* server = "api.thingspeak.com";
const uint8_t MPU_addr=0x68; // I2C address of the MPU-6050
const float MPU_GYRO_250_SCALE = 131.0;
const float MPU_GYRO_500_SCALE = 65.5;
const float MPU_GYRO_1000_SCALE = 32.8;
const float MPU_GYRO_2000_SCALE = 16.4;
const float MPU_ACCL_2_SCALE = 16384.0;
const float MPU_ACCL_4_SCALE = 8192.0;
const float MPU_ACCL_8_SCALE = 4096.0;
const float MPU_ACCL_16_SCALE = 2048.0;
float ax;
float ay;
float az;
float gx;
float gy;
float gz;
float tmp;
struct rawdata {
int16_t AcX;
int16_t AcY;
int16_t AcZ;
int16_t Tmp;
int16_t GyX;
int16_t GyY;
int16_t GyZ;
struct scaleddata{
float AcX;
float AcY;
float AcZ;
float Tmp;
float GyX;
float GyY;
float GyZ;
bool checkI2c(byte addr);
void mpu6050Begin(byte addr);
rawdata mpu6050Read(byte addr, bool Debug);
void setMPU6050scales(byte addr,uint8_t Gyro,uint8_t Accl);
void getMPU6050scales(byte addr,uint8_t &Gyro,uint8_t &Accl);
scaleddata convertRawToScaled(byte addr, rawdata data_in,bool Debug);
//DHT dht(DHTPIN, DHT11);
//Adafruit_BMP085 bmp;
WiFiClient client;
Wire.begin();
// delay(10);
mpu6050Begin(MPU_addr);
// Wire.begin(4, 5);
// if (!bmp.begin()) {
// Serial.println("Could not find a valid BMP180 sensor, check wiring!");
// while (1);
// dht.begin();
WiFi.begin(ssid, password);
Serial.print("Connecting with ");
Serial.println(ssid);
Serial.print("Connect failed");
Serial.println("");
Serial.println("WiFi Connected");
rawdata next_sample;
setMPU6050scales(MPU_addr,0b00000000,0b00010000);
next_sample = mpu6050Read(MPU_addr, true);
convertRawToScaled(MPU_addr, next_sample,true);
delay(5000); // Wait 5 seconds and scan again
// float temp = bmp.readTemperature();
// float pressure = bmp.readPressure();
// pressure = pressure / 100; //Convert to hPa
// float humidity = dht.readHumidity();
if (client.connect(server, 80)) {
String postStr = apiKey;
postStr += "&field1=";
postStr += String(gx, 6);
postStr += "&field2=";
postStr += String(gy, 6);
postStr += "&field3=";
postStr += String(gz, 6);
postStr += "&field4=";
postStr += String(ax, 6);
postStr += "&field5=";
postStr += String(ay, 6);
postStr += "&field6=";
postStr += String(az, 6);
postStr += "&field7=";
postStr += String(tmp, 4);
postStr += "\r\n\r\n";
client.print("POST /update HTTP/1.1\n");
client.print("Host: api.thingspeak.com\n");
client.print("Connection: close\n");
client.print("X-THINGSPEAKAPIKEY: " + apiKey + "\n");
client.print("Content-Type: application/x-www-form-urlencoded\n");
client.print("Content-Length: ");
client.print(postStr.length());
client.print("\n\n");
client.print(postStr);
Serial.println("Temp: " + String(temp) + " Pressure: " + String(pressure) + " Humidity: " + String(humidity));
Serial.println(postStr);
client.stop();
delay(5000);
void mpu6050Begin(byte addr){
// This function initializes the MPU-6050 IMU Sensor
// It verifys the address is correct and wakes up the
// MPU.
if (checkI2c(addr)){
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // set to zero (wakes up the MPU-6050)
Wire.endTransmission(true);
delay(30); // Ensure gyro has enough time to power up
bool checkI2c(byte addr){
// We are using the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Serial.println(" ");
Wire.beginTransmission(addr);
if (Wire.endTransmission() == 0)
Serial.print(" Device Found at 0x");
Serial.println(addr,HEX);
return true;
Serial.print(" No Device Found at 0x");
return false;
rawdata mpu6050Read(byte addr, bool Debug){
// This function reads the raw 16-bit data values from
// the MPU-6050
rawdata values;
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(addr,14,true); // request a total of 14 registers
values.AcX=Wire.read()<<8|Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
values.AcY=Wire.read()<<8|Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
values.AcZ=Wire.read()<<8|Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
values.Tmp=Wire.read()<<8|Wire.read(); // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
values.GyX=Wire.read()<<8|Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
values.GyY=Wire.read()<<8|Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
values.GyZ=Wire.read()<<8|Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
if(Debug){
Serial.print(" GyX = "); Serial.print(values.GyX);
Serial.print(" | GyY = "); Serial.print(values.GyY);
Serial.print(" | GyZ = "); Serial.print(values.GyZ);
Serial.print(" | Tmp = "); Serial.print(values.Tmp);
Serial.print(" | AcX = "); Serial.print(values.AcX);
Serial.print(" | AcY = "); Serial.print(values.AcY);
Serial.print(" | AcZ = "); Serial.println(values.AcZ);
return values;
void setMPU6050scales(byte addr,uint8_t Gyro,uint8_t Accl){
Wire.write(0x1B); // write to register starting at 0x1B
Wire.write(Gyro); // Self Tests Off and set Gyro FS to 250
Wire.write(Accl); // Self Tests Off and set Accl FS to 8g
void getMPU6050scales(byte addr,uint8_t &Gyro,uint8_t &Accl){
Wire.write(0x1B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.requestFrom(addr,2,true); // request a total of 14 registers
Gyro = (Wire.read()&(bit(3)|bit(4)))>>3;
Accl = (Wire.read()&(bit(3)|bit(4)))>>3;
scaleddata convertRawToScaled(byte addr, rawdata data_in, bool Debug){
scaleddata values;
float scale_value = 0.0;
byte Gyro, Accl;
getMPU6050scales(MPU_addr, Gyro, Accl);
if(Debug){
Serial.print("Gyro Full-Scale = ");
switch (Gyro){
case 0:
scale_value = MPU_GYRO_250_SCALE;
if(Debug){
Serial.println("±250 °/s");
case 1:
scale_value = MPU_GYRO_500_SCALE;
if(Debug){
Serial.println("±500 °/s");
case 2:
scale_value = MPU_GYRO_1000_SCALE;
if(Debug){
Serial.println("±1000 °/s");
case 3:
scale_value = MPU_GYRO_2000_SCALE;
if(Debug){
Serial.println("±2000 °/s");
default:
values.GyX = (float) data_in.GyX / scale_value;
values.GyY = (float) data_in.GyY / scale_value;
values.GyZ = (float) data_in.GyZ / scale_value;
scale_value = 0.0;
if(Debug){
Serial.print("Accl Full-Scale = ");
switch (Accl){
case 0:
scale_value = MPU_ACCL_2_SCALE;
if(Debug){
Serial.println("±2 g");
case 1:
scale_value = MPU_ACCL_4_SCALE;
if(Debug){
Serial.println("±4 g");
case 2:
scale_value = MPU_ACCL_8_SCALE;
if(Debug){
Serial.println("±8 g");
case 3:
scale_value = MPU_ACCL_16_SCALE;
if(Debug){
Serial.println("±16 g");
default:
values.AcX = (float) data_in.AcX / scale_value;
values.AcY = (float) data_in.AcY / scale_value;
values.AcZ = (float) data_in.AcZ / scale_value;
values.Tmp = (float) data_in.Tmp / 340.0 + 36.53;
if(Debug){
Serial.print(" °/s| GyY = "); Serial.print(values.GyY);
Serial.print(" °/s| GyZ = "); Serial.print(values.GyZ);
Serial.print(" °/s| Tmp = "); Serial.print(values.Tmp);
Serial.print(" °C| AcX = "); Serial.print(values.AcX);
Serial.print(" g| AcY = "); Serial.print(values.AcY);
Serial.print(" g| AcZ = "); Serial.print(values.AcZ);Serial.println(" g");
gx = values.GyX;
gy = values.GyY;
gz = values.GyZ;
tmp = values.Tmp;
ax = values.AcX;
ay = values.AcY;
az = values.AcZ;
return values;
Moderator edit: sorted
thingspeak_mpu6050_v2.ino (8.48 KB)
