Stray capacitance on PCB (32kHz Crystal Cx calculation)
Hello,
There are several equations for external capacitor calculation, this explanation is the most convincing to me, which contains:
kép
The crystal datasheet specifies 12,5pF as load capacitance. The crystal itself will be just a backup option, so on the PCB there are currently two unpopulated 0805 footprints which can be soldered (into a short) if needed.
What would be a good stray capacitance guesstimation for this layout?
(bottom layer is GND pour, standard 1.6mm FR4 material, 1oz copper weight)
Thanks in advance.
The 12.5 pf load capacitance is the value that the manufacturer used to tune the crystal to the specified frequency. Using a different value can 'pull' the crystal to oscillate at a slightly different frequency.
18pF would be a good start, which gives you 9pF without the board.
Leo..
Yes, this is why I tried to choose the needed value with caution.
Thanks! Stray capacitance is usually assumed to be 2-5 pF with short traces, which results in 20pF-15pF load capacitors based on the formula in #1. Also considering that the basic (cheap) C0G capacitors at the PCB assembler company have +-5% tolerance, I will go with this middle value.
