strcmp() & if() & else if() Help
Hey all! I’ll keep this short, sweet, and to the point.
While trying to clean up the code for a project I’m working on, I was made aware of the fact that I can remove a couple of variables and save some RAM by using the strcmp() function. The gist is I was taking a char array, turning it into a string, then comparing the two strings using
char myChar = [long messy function to grab user input];
String stringOne = myChar myChar;
if (stringOne == "something")
  if (stringTwo == "something") {...}
else if (stringOne == "something else") {...}
While this worked fine, it is a memory hog because it’s not just stringOne, it’s up to stringFour. Someone on reddit mentioned I could do away with stringOne etc. and use strcmp(), which does function. For one level of the command input I’m building. When I change it to
char myChar = [user input]
if (strcmp(stringOne, "something")) {...}
else if (strcmp(stringOne, "something else")) {...}
I get the error of “else statement without previous if” when I attempt to compile.
So in my first example the user input would be something like <part1/part2/part3/part4>. I have a function that reads the stuff between “<>” and breaks it into separate pieces at the “/”. If I remove all the “else” statements and leave them as plain “if” statements my program will compile, however if any command is entered it will run every single command. If I leave the “else” it fails to compile.
Does anyone know why this is and what I should do to fix it? Should I just stick with my original method that works but uses unnecessary memory?
error: "else statement without previous if" happens when you have an ill-form statement like:
if (true); {
} else{
Also, strcmp() expects two cstring (null terminated char array) and not String object.
Also 2, strcmp() return 0 when the two cstrings are equal. And 0 is interpreted as false.
@arduino_new replied while I was writing this, but there is a bit of additional information so I'll post it anyway:
Please post your actual code.
Note that strcmp returns 0 when the two strings are identical. So the code in your if and else if blocks will only execute when the strings don't match. Even if that's what you intended, I think it's not best practices to treat strcmp as if it returns a boolean. The logical assumption would be that strcmp returns true when the strings match, but this is not how it works. So it's more clear to do an explicit comparison:
if (strcmp(stringOne, "something") != 0) {  // the strings don't match
or:
if (strcmp(stringOne, "something") == 0) {  // the strings match
Reference:
http://www.cplusplus.com/reference/cstring/strcmp/
