Stream 3 audio signals (Piezo sensors) to PC via USB using arduino and PCM1803
Dear community,
I would like to get your help.
for a project to my engineering degree, I need to convert 3 analog signals, from piezo sensors, 20hz to 40Khz, then I would like to get this signal in the computer and perform some analysis and produce sound.
I got 2 PCM1803 breakout boards of sparkfun (Stereo Analog to Digital converters).
Currently I have Teensy 2.0 but I can also get Arduino Uno.
I would like to stream in the best quality, 24 bit, 96Khz the signal and receive it in the PC.
I am looking at the PCM1803 but I have no idea how to communicate between this board to the Arduino\Teensy.
I see that the PCM1803 have I2S interface, but i do not have an idea how to work with it.
I will be glad to get any advice, and also, if you have a better solution.
Thanks in advance,
Alon
