Hi guys, just getting into wifi stuff now with the ESP32 and I am a bit stuck..
I would like to run the following sketch as an access point rather that a server (I hope I am using the right terminoligy)
Basically instead of connecting my ESP32 to my router then connecting to it via the router, I would like to be able to connect directly to the ESP32.
Any tips?
#include <WiFi.h> // Part of ESP32 board libraries
#include <WebServer.h> // Part of ESP32 board libraries
#include <WebSocketsServer.h> // Installed "WebSockets" library
#include <Adafruit_AMG88xx.h> // Installed "Adafruit_AMG88xx" library
Adafruit_AMG88xx amg;
float pixels[AMG88xx_PIXEL_ARRAY_SIZE];
WebServer server(80);
WebSocketsServer webSocket = WebSocketsServer(81);
char* ssid = "wifi_ssid_to_connect_to";
char* password = "wifi_password";
char webpage[] PROGMEM = R"=====(
<html>
<head>
<style>
#thermcam td {
width: 30;
height: 30;
</style>
<script>
var Socket;
var streamframestimer;
var sizesensor = [8,8];
var minTsensor = 0.0;
var maxTsensor = 80.0;
var minT = 15.0; // initial low range of the sensor (this will be blue on the screen)
var maxT = 50.0; // initial high range of the sensor (this will be red on the screen)
var currentFrame = [];
var minTframe = maxTsensor;
var maxTframe = minTsensor;
var minTframelocation = [0,0];
var maxTframelocation = [0,0];
var camColors = [
"1500BF", "0900BF", "0003C0", "0010C0", "001DC1", "002AC2", "0037C2", "0044C3",
"0052C3", "005FC4", "006DC5", "007AC5", "0088C6", "0095C6", "00A3C7", "00B1C8",
"00BFC8", "00C9C4", "00C9B8", "00CAAB", "00CB9E", "00CB90", "00CC83", "00CC76",
"00CD68", "00CE5B", "00CE4D", "00CF40", "00CF32", "00D024", "00D116", "00D109",
"05D200", "13D200", "21D300", "2FD400", "3DD400", "4CD500", "5AD500", "69D600",
"78D700", "86D700", "95D800", "A4D800", "B3D900", "C2DA00", "D1DA00", "DBD500",
"DBC700", "DCB900", "DDAA00", "DD9C00", "DE8E00", "DE7F00", "DF7100", "E06200",
"E05300", "E14400", "E13500", "E22600", "E31700", "E30800", "E40006", "E50015",
function mapto( val, minin, maxin, minout ,maxout ){
if ( val >= maxin ){
return maxout;
} else if ( val <= minin ){
return minout;
return ((( ( maxout - minout )/( maxin - minin ) ) * val ) + ( minout - ( ( maxout - minout )/( maxin - minin ) ) * minin ));
function adjusttemrange(range,adjustment){
if ( range == "min" ){
if ( adjustment == 0){
minT = minTframe;
minT += adjustment;
if ( range == "max" ){
maxT = maxTframe;
maxT += adjustment;
if ( minT < minTsensor ){
minT = minTsensor;
if ( maxT > maxTsensor ){
maxT = maxTsensor;
if ( minT >= maxT ){
minT = maxT - 1.0;
fillthermcamtable(currentFrame);
document.getElementById("minT").innerHTML = minT.toFixed(2) + "C";
document.getElementById("maxT").innerHTML = maxT.toFixed(2) + "C";
function ctof(tempc){
return (tempc * ( 9 / 5 ) ) + 32;
function buildthermcamtable(){
var thermcamTable = document.getElementById("thermcam");
for(i=0;i<sizesensor[0];i++){
var row = thermcamTable.insertRow(i);
for(j=0;j<sizesensor[1];j++){
var cell = row.insertCell(j);
cell.id = "tccell"+((i*8)+j);
function fillthermcamtable(pixelarray){
// Fill table
// Temps in C and F in cells
// BG color of cells use camColors
// Update minTframe and maxTframe
var idx = ((i*8)+j);
var cell = document.getElementById("tccell"+idx);
var camcolorvalue = Math.round( mapto( pixelarray[idx], minT , maxT, 0 ,63 ) );
cell.innerHTML = pixelarray[idx].toFixed(2) + "C " + ctof( pixelarray[idx] ).toFixed(2) + "F";
cell.style.backgroundColor = "#" + camColors[camcolorvalue];
cell.className = "camcolorvalue" + camcolorvalue;
if ( pixelarray[idx] < minTframe ){
minTframe = pixelarray[idx];
minTframelocation = [j,i];
if ( pixelarray[idx] > maxTframe ){
maxTframe = pixelarray[idx];
maxTframelocation = [j,i];
document.getElementById("minTframedata").innerHTML = minTframe.toFixed(2) + "C " + ctof( minTframe ).toFixed(2) + "F (" + minTframelocation[0] + "," + minTframelocation[1] + ")";
document.getElementById("maxTframedata").innerHTML = maxTframe.toFixed(2) + "C " + ctof( maxTframe ).toFixed(2) + "F (" + maxTframelocation[0] + "," + maxTframelocation[1] + ")";
function init() {
// Build table
buildthermcamtable();
Socket = new WebSocket('ws://' + window.location.hostname + ':81/');
Socket.onmessage = function(event){
if ( event.data[0] == '[' ){
currentFrame = JSON.parse(event.data);
function sendText(){
Socket.send(document.getElementById("txBar").value);
document.getElementById("txBar").value = "";
function getframe(){
Socket.send("F");
function streamframes(){
streamframestimer = setTimeout( streamframes , 200 );
getframe();
function stopstreamframes(){
clearTimeout( streamframestimer );
</script>
</head>
<body onload="init()">
<table id="thermcam">
</table>
<hr/>
<table id="thermcamcontrols">
<tr>
<td>Min Temp</td>
<td id="minT"></td>
<td><button type="button" onclick="adjusttemrange('min',-5);">-5C</button></td>
<td><button type="button" onclick="adjusttemrange('min',-1);">-1C</button></td>
<td><button type="button" onclick="adjusttemrange('min', 0);">lowest in current frame</button></td>
<td><button type="button" onclick="adjusttemrange('min',+1);">+1C</button></td>
<td><button type="button" onclick="adjusttemrange('min',+5);">+5C</button></td>
<td id="minTframedata"></td>
</tr>
<tr>
<td>Max Temp</td>
<td id="maxT"></td>
<td><button type="button" onclick="adjusttemrange('max',-5);">-5C</button></td>
<td><button type="button" onclick="adjusttemrange('max',-1);">-1C</button></td>
<td><button type="button" onclick="adjusttemrange('max', 0);">highest in current frame</button></td>
<td><button type="button" onclick="adjusttemrange('max',+1);">+1C</button></td>
<td><button type="button" onclick="adjusttemrange('max',+5);">+5C</button></td>
<td id="maxTframedata"></td>
</tr>
</table>
<hr/>
<div>
<button type="button" onclick="getframe();">Get Frame</button>
<button type="button" onclick="streamframes();">Start Stream Frames</button>
<button type="button" onclick="stopstreamframes();">Stop Stream Frames</button>
</div>
</body>
</html>
WiFi.begin(ssid,password);
while(WiFi.status()!=WL_CONNECTED)
Serial.print(".");
Serial.println("");
Serial.print("IP Address: ");
server.on("/",[](){
server.send_P(200, "text/html", webpage);
server.begin();
webSocket.begin();
webSocket.onEvent(webSocketEvent);
Wire.begin(13,15); // AMG8833 sensor usin 13 as SDA and 15 as SCL
if (!amg.begin()) {
Serial.println("Could not find a valid AMG88xx sensor, check wiring!");
while (1);
webSocket.loop();
server.handleClient();
if(Serial.available() > 0){
char c[] = {(char)Serial.read()};
webSocket.broadcastTXT(c, sizeof(c));
void webSocketEvent(uint8_t num, WStype_t type, uint8_t * payload, size_t length){
if(type == WStype_TEXT){
if(payload[0] == 'F'){ // i.e. "Frame"
amg.readPixels(pixels);
String thermalFrame = "[";
for (int i = 1; i < AMG88xx_PIXEL_ARRAY_SIZE + 1; i++) { // Starts at 1 so that (i % 8) will be 0 at end of 8 pixels and newline will be added
thermalFrame += pixels[i - 1];
if ( i != AMG88xx_PIXEL_ARRAY_SIZE ){
thermalFrame += ", ";
if ( i % 8 == 0 ) thermalFrame += "\n";
thermalFrame += "]";
char tf[thermalFrame.length()+1];
thermalFrame.toCharArray( tf, thermalFrame.length()+1 );
Serial.println(tf);
webSocket.broadcastTXT(tf, sizeof(tf)-1);
} else{
for(int i = 0; i < length; i++)
Serial.print((char) payload[i]);
