I am currently in the process of designing a portable bluetooth speaker and am in need of some guidance when it comes to choosing the right bluetooth module for the task.
I basically would like to be able to connect to a single bluetooth module in order to stream audio to the speaker and control addressable Led strips built into the speaker via an app using a UART serial connection.
Does this sound like something that is possible? If so, any recommendations for a module that is suitable for this application would be greatly appreciated!
I have found the "SparkFun Audio Bluetooth Breakout - RN-52" which to me, sounds like it would be perfect for the job. But I really am new to this so could be totally wrong! Plus, a big downside being that it is only bluetooth 3.0 and has no option for an external antenna so once inside a speaker cabinet, the range might not be amazing.
I use a ESP32 combined with an i2s amplifer. You can get a cheaper ESP32 but the sparfun one has built in lipo power management and the regulator can output a decent amount of power.
See my code here for doing bluetooth audio with ESP32. this should be enough to get you going.
