Streaming data into arduino
Is there any software to feed data into an arduino serial, such as ‘Gcode sender’; but I don’t want to send gcodes, just some numbers seperated by ‘comma’.
Example:
PC to arduino → 897,589
(arduino performs the work)
Arduino to PC → Ready
PC to arduino → 75,241
… continues.
Is there any software available, like MegunoLink, or can I combine it with Processing?
You can just use Processing.
Have a look at the serial example code:
 * Serial Call-Response
 * by Tom Igoe.
 * Sends a byte out the serial port, and reads 3 bytes in.
 * Sets foregound color, xpos, and ypos of a circle onstage
 * using the values returned from the serial port.
 * Thanks to Daniel Shiffman  and Greg Shakar for the improvements.
 * Note: This sketch assumes that the device on the other end of the serial
 * port is going to send a single byte of value 65 (ASCII A) on startup.
 * The sketch waits for that byte, then sends an ASCII A whenever
 * it wants more data.
import processing.serial.*;
int bgcolor;			     // Background color
int fgcolor;			     // Fill color
Serial myPort;                       // The serial port
int[] serialInArray = new int[3];    // Where we'll put what we receive
int serialCount = 0;                 // A count of how many bytes we receive
int xpos, ypos;		             // Starting position of the ball
boolean firstContact = false;        // Whether we've heard from the microcontroller
  size(256, 256);  // Stage size
  noStroke();      // No border on the next thing drawn
  // Set the starting position of the ball (middle of the stage)
  xpos = width/2;
  ypos = height/2;
  // Print a list of the serial ports, for debugging purposes:
  printArray(Serial.list());
  // I know that the first port in the serial list on my mac
  // is always my  FTDI adaptor, so I open Serial.list()[0].
  // On Windows machines, this generally opens COM1.
  // Open whatever port is the one you're using.
  String portName = Serial.list()[0];
  myPort = new Serial(this, portName, 9600);
void draw() {
  background(bgcolor);
  fill(fgcolor);
  // Draw the shape
  ellipse(xpos, ypos, 20, 20);
void serialEvent(Serial myPort) {
  // read a byte from the serial port:
  int inByte = myPort.read();
  // if this is the first byte received, and it's an A,
  // clear the serial buffer and note that you've
  // had first contact from the microcontroller.
  // Otherwise, add the incoming byte to the array:
  if (firstContact == false) {
    if (inByte == 'A') {
      myPort.clear();          // clear the serial port buffer
      firstContact = true;     // you've had first contact from the microcontroller
      myPort.write('A');       // ask for more
  else {
    // Add the latest byte from the serial port to array:
    serialInArray[serialCount] = inByte;
    serialCount++;
    // If we have 3 bytes:
    if (serialCount > 2 ) {
      xpos = serialInArray[0];
      ypos = serialInArray[1];
      fgcolor = serialInArray[2];
      // print the values (for debugging purposes only):
      println(xpos + "\t" + ypos + "\t" + fgcolor);
      // Send a capital A to request new sensor readings:
      myPort.write('A');
      // Reset serialCount:
      serialCount = 0;
//  Serial Call and Response
//  by Tom Igoe
//  Language: Wiring/Arduino
//  This program sends an ASCII A (byte of value 65) on startup
//  and repeats that until it gets some data in.
//  Then it waits for a byte in the serial port, and
//  sends three sensor values whenever it gets a byte in.
//  Thanks to Greg Shakar for the improvements
//  Created 26 Sept. 2005
//  Updated 18 April 2008
int firstSensor = 0;    // first analog sensor
int secondSensor = 0;   // second analog sensor
int thirdSensor = 0;    // digital sensor
int inByte = 0;         // incoming serial byte
  // start serial port at 9600 bps:
  pinMode(2, INPUT);   // digital sensor is on digital pin 2
  establishContact();  // send a byte to establish contact until Processing responds
  // if we get a valid byte, read analog ins:
  if (Serial.available() > 0) {
    // get incoming byte:
    inByte = Serial.read();
    // read first analog input, divide by 4 to make the range 0-255:
    firstSensor = analogRead(0)/4;
    // delay 10ms to let the ADC recover:
    delay(10);
    // read second analog input, divide by 4 to make the range 0-255:
    secondSensor = analogRead(1)/4;
    // read  switch, multiply by 155 and add 100
    // so that you're sending 100 or 255:
    thirdSensor = 100 + (155 * digitalRead(2));
    // send sensor values:
    Serial.write(firstSensor);
    Serial.write(secondSensor);
    Serial.write(thirdSensor);
void establishContact() {
 while (Serial.available() <= 0) {
      Serial.write('A');   // send a capital A
      delay(300);
You may be interested in this Python - Arduino demo. The Python code could easily be extended to read data from a file on the PC.
See also Serial Input Basics
...R
Robin2:
...R
How do I run the python code?
What is the purpose of this? If it’s a one-time thing, under a person’s control then just copy-paste the data into the serial monitor. Other terminal programs like Putty or Realterm can take bigger chunks of data.
Rajdeep_Banik:
The same way you run any program on a PC - you need to have the Python interpreter installed on your PC.
I'm not sure exactly what you are asking ?
Have you tried to run the program ?
...R
Is there any software to feed data into an arduino serial, such as 'Gcode sender'; but I don't want to send gcodes, just some numbers seperated by 'comma'.
If you use windows, you could just use batch files with the arduino (with the serial reset defeated).
