Hello, from a programming point of view is it possible to stream an image to an arduino board and outputting it to a tft lcd screen without having the image stored in the arduino itself?
The reason I’m asking is because I have an image that used dates every 200ms. Basically it refreshing in its on from software that screenshots the computer health information and stores it into a png image every 200ms by replacing what information was on it previously.
I was just wondering if I can stream it instead of storing it.
You can definitely send each image and have the Arduino display the image - not sure if even an ESP32 will sustain 5Hz, I guess it depends on the image format and size and screen API
@J-M-L hey. The image is a 1024x765. I guess the image it takes saves it at that resolution and I can’t change that becuase it is an older software that still working on windows11. The image is in png format.
My tft lcd is a 3.5” screen non touch I use for testing things. It’s in a metro grand station central board.
Determine the bits per second. What radio or BUS can handle that. If you find a candidate, then throwing it on a screen should be doable.
HOWEVER, if you can only send the delta between frames, you will have many more choices due to much lower bandwidth needed.
Q: 48 bits/pixel HD full color or 1 bit / pixel monochrome (BW) or in between?
Q: compression ON/OFF?
Assuming no compression and 1 bits / pixel
1024 x 765 = 783.360 pixels, ~ 800.000 bits
5 x per second => 4 Mb / second sustained, you definitely need a 100 Mb ethernet and one of the fastest boards you can find (Teensy, ESP32, RP2040)
Use compression, run length encoding could reduce the amount of bits, and ease the processing for monochrome.
What kind of information is on the screen?
Do you have a screenshot to share?
You could write a simple python script on the PC and send just the numeric data to the Arduino. There is a Python module named psutils that gives you a ton of information.
