I have to send a long string (>10 000 char) through my ENC28J60 with ESP8266. Streamlib.h is a great library for sending streams (link). But here it is impossible due to calculation duration, the software WDT makes a reset.
I have already put a yield() inside :
size_t BufferedPrint::write(const uint8_t *buf, size_t length)
yield();
for (size_t...
Helped a lot but did not solved. Still crashing while writting.
Replacing BufferedPrint by ChunkedPrint was indeed suffiscent.
Maybe I did not get what BufferedPrint print was doing, I thought it used a small buffer to send data, obviously that's what ChunkedPrint print is doing.
ChunkedPrint extends BufferedPrint and changes the output to http chunked transfer encoding. size of the chunks is the size of the provided buffer.
I don't see how it helped.
I am using EthernetENC.h. Do you think lwip_enc28j60 library could be more reliable?
In my further development I look forward HTTPS libraries, which require ESP32.
I took a look at the lwip libraries from khoih-prog. Hard to pick up the right one. I think this one should do the work, together with Streamlib to chunk streams.
